Results 1 to 10 of 21
Thread: Paint Shield Questions
    Jul 2012
    Perth- South of the River
    Hey Scott (and anyone else with experience),
    Questions:
    How does it look when on, not overly important if applying for a trip, but curious if it's obvious once applied?
    How long does it last? Do you peel off after a trip and re-apply for next time? Or leave in on longer term?
    How hard is it to remove?
    What's it like after removal? Clean? Does it leave any residue?
    How much do you need? Does the 4ltr have enough for 1? or more applications.
    Thanks in advance.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    Feb 2017
    Definitely works for most scrub scratching down the sides and over sides of bonnet
    Doesn’t do squat for blacked out areas
    Peels off clean and easily
    Odd bits can be power washed off
    One application good for 1 week IMO but depends on how bad you abuse it (scratches)
    4 liters will go a long way (I’d say easily 4 applications)
    Make sure you use a 12mm minimum nap roller so it goes on thick
    Looks dull but clear once applied
    Recommended.
    Jul 2012
    Quote Originally Posted by BrianElloy View Post
    Recommended.
    Thanks for the information Brian. I think I'll give it a go.
    Sep 2014
    Baldivis WA
    Never heard of this stuff but sounds impressive, must be like a 3M clear film when dried and applied.
    Oct 2014
    A duller satin finish. I think it looks good for trips and if applied evenly looks reasonable even long term.
    I remember Rich used to leave it on for months on his D3
    Instructions say 3 months but will stay on much longer. I've had it on for 5 weeks without any degradation.
    It's quite easy to remove once wet and using a pressure washer to get the peeling started at edges works well.
    Some edges get difficult to remove because it's hard to avoid thin feathered edges.
    As above, the little bits left behind are harder to remove if thin but everything comes off cleanly.
    You'd get around 10 applications from the 4L tub. I now have a 15L tub.
    Paint Shield
    I have found it best to roll on 3 layers, nice and even. This leaves a thick, strong film.
    Best to mask the grey trim and window surrounds because it's difficult to remove from those surfaces.
    However works very well on the black trim (a-pillar and door trim).
    It turns milky and soft if it gets wet but will recover if allowed to dry, especially if applied at a decent thickness.
    Linked below is an older thread that mentions a few other similar products.
    PAINT PROTECTION FILM, HAS ANYONE USED IT?
    Photos below show what it looks like part way through before drying fully.
    Then a couple of photos with it on, although not the best photos for showing how it looks.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Jul 2012
    Awsome, thanks for the detailed information and photos. This will be on the car prior to it's first bush outing.
    Sep 2014
    Baldivis WA
    I like the satin finish, looks great,and if it saves the paint, then I'm all for it.
    Oct 2016
    I use Carpro cquartz dlux on my plastic and rubber trims to protect them from UV damage. I’ve noticed that paint shield will not stick to any trim coated in dlux, it beads off. So you don’t need to do as much preparation with masking tape
    D4 SDV6 MY16 HSE Corris Grey with Rhino Backbone Pioneer Tray, Traxide TBS, APT full Armadillo, Llams, Travall Barrier, 19" Cooper Zeon LTZ, Tow Pro Elite, UHF GME XRS-370C
    May 2015
    I've been using Road Warrior Plus which I believe is essentially the same thing. I like the look when its on and concur with all the positives mentioned above. The Australian supplier sent me a message recently to say they are closing down and selling it off much more cheaply as a result. Maybe worth a look for you
    Road Warrior Plus - 1 Bottle / Road Warrior Plus Australia
    2014 D4 HSE, Traxide Dual Battery System, llams, Compomotive Rims, Prospeed Roof Rack, Rock Sliders and Compressor Guard.
    Oct 2014
    Quote Originally Posted by LRD414 View Post
    Scott - do you apply it to the side mirrors and if so, do you find it difficult to remove from these?
    Mario
