Results 1 to 3 of 3
Thread: Compressor Bash Plate
    4.28 MB
    I have a GOE compressor plate and I need to remove it but one of the bolts on the side spins and I presume the captive nut has worked loose. I've tried a lever under the bolt to create compression but it still spins (nut rusted on to bolt most likely). Is there any other way into the nut?
    Rod
    D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
    Nov 2015
    Black Rock
    What a pain. Might have to angle grind it off. May need to replace it with a rivnut or something similar.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Jan 2018
    I'd be trying a good quality penetrating oil like liquid wrench which is designed to loosen rusted fasteners... spray on, go for a cup of tea, come back and spray some more, then try the screwdriver trick again... otherwise you'll most likely be cutting it off.
