Here is what I used when I did mine:
Changed the Transmission oils, colour compare pics.
Hi Guys
i am looking to do all the diff and transfer oils in my Disco 4 3 litre 2010 i am going to use the
Castrol Syntrax 70w90 long life in the front diff
transfer case oil i am a little stuck on thinking royal purple syncromax transmission fluid
rear E Diff castrol SAF carbon Mod Plus from the UK
i have done the transmission with ZF6 fluid.
how does this sound, i have read that people have used Penrite GL 5 pro gear oil for the front diff and transfer cases. does any one have recommendations for the above diffs and transmission.
Adam.
2010 D4 3litre twin turbo brand new motor 5km old on a 100,000km car. Kaymar rear bar, ARB front bar, Hannibal roof rack, Hella Predator Spot lights, long rand fuel tank, Traxide battery management. touring weapon.
+ 2016 D4 TDV6
I've been using royal purple syncromax in my transfer case for some time now. Previously I've used Penrite Pro Gear 75w/90 (synthetic) in my diffs, however the last change I've swapped to Penrite Gear oil 85W/140(mineral) as I want to track the wear between the two oils. For the record the front diff is a lot harder on the oil compared to the rear in my case, but I don't have a rear ediff either. As long as the oil you use meets a GL-5 spec then you should be fine in the front diff. With the rear e-diff I don't think theres much on the market that meets LR spec so you might be stuck hunting for the Castrol oil there
Shane
2005 D3 TDV6 loaded to the brim with 4 kids!
http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
You can get the e-diff oil from Holden part # GMH 92184900.
Fuji white RRS L494 AB Gone
2023 Ford Ranga
Or penrite now too, on the shelf at super cheap.
I just put this in both diffs saves me having two bottles and pumps.
Transfer case I just buy the genuine as it's easy to get locally.
