Results 1 to 10 of 18
Thread: Electric Vehicles - Air Con
    Apr 2019
    Would I be right that a 12v compressor would run the system?
    Is there is off the shelf similar
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Jan 2010
    You can get a 12v ac compressor.
    Tesla run heater matrix and AC comp directly off high voltage battery pack. As high as 400v
    What's the application?
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Homestar View Post
    Don’t they just!
    Certainly wouldn’t want to leave it running the vehicle off.
    Jan 2010
    Don’t they just!
    Depends on the set up. You can sleep in the back of a Tesla and have the AC running all night. Uses up a few measly percent Electric Vehicles - Air Con
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by manic View Post
    As it would at night when the heat load is a couple of hundred watts and you are sleeping on a 60KWh battery.
    Frankly at 400V and 60KWh a Tesla battery would power my House ducted A/C for close to 3 days (72 hrs) in the heat of summer. I could hook it straight up to the PFC rectified bus and just switch it on. I'd have a bugger of a time driving the house anywhere though.
    BLDC compressors are the future as the cornerstone of a fully hermetic automotive system with no potential for leaks. That's a relatively long way off however.
    Brisbane,some of the time.
    Quote Originally Posted by BradC View Post
    Full hermetic systems have been around for years,and yes they can all leak refrigerant,no matter how well they are built......
    Jul 2011
    Yarrawonga, Vic
    EV don't use the 12V supply for AirCon, The 12V battery is minuscule and is used for lights / contactors etc , if the 12V battery goes flat the EV is dead.
    How does air conditioning work in an electric car? | AutoGuru
    Jul 2011
    Yarrawonga, Vic
    Here we go, even got a picture of a Defender in the ad
    320V lithium battery vehicle compressor
    Torres Straits
    Dometic do 12V and 24V fully configured AC units for the cab
    Their 12V unit eats 40A on min setting
    Dometic's truck air conditioner adds a new 12-volt version | Dometic
    On my old 130Tdi I had considered plonking one of these in the roof
    No different to normal AC you’d just set it so it can only operate with engine running
    Much easier to run a couple of cables than the plumbing and wiring of a bet driven compressor.
    S
