Harlie
With or without Xenon headlights ?
Laurie
Hello
I've searched but not found.... Is there replacement lens available for the 2008 headlights?
I have badly sun damaged plastics, sanding and polishing has made a huge improvement but I'm still not real happy with them - I know we can get the glass for a 2004.
Harlie
Laurie
Harlie
Not sure, but part numbers below might help.
With
https://allbrit.de/epc.cfm?PAGE=4170...TLJ&SPRACHE=EN
Without
Laurie
Thanks,
I have:
Headlamps - Bi-Xenon (for low & high beam)
Headlamps - Active (Cornering/steering)
looks like I need this page - HEADLAMPS AND FRONT FLASHER LAMPS (FROM (V)6A000001 TO (V)9A999999) - RANGE ROVER (D4) 2002-2009 ? Can't see a replacement Lens, it has clips and looks like it should be easy to remove.....
Found 2010-12 Range Rover Vogue L322 - Headlight lens plastic covers
Still searching for 2006-09
I have a machine polisher you can try. Cutting compound with polisher usually works ok on other cars but I also need to use it on my L322.
L322 tdv8 poverty pack - wow
Track Trailer ARN 200-117
REMLR # 137
Thanks Pete - they were so bad I started with 1200 wet/dry sandpaper, then 1500, then 2000, then 2500, then polish - all using a 3inch machine. Spent quite a few hours on them (removed from car) and was actually happy when done - however, 1 week on and they already look a bit naff.....
I found Disco4 on Aliexpress for a resonable cost but so far I have not found 06-09 L322.
At least the 2008 L322 headlights are not too badly priced, compared to the 2010 facelift headlights.
Mine are a bit pitted, so might buy replacements too next year.
REMLR # 137
GMS Spares at Riversly NSW have a used set. Also cloudy. See Gumtree.
REMLR # 137
