Results 1 to 10 of 23
Thread: A/C Not Working
    Brissy! No flannos here!
    A/C Not Working
    Hi All,
    My A/C has stopped working all of a sudden. And I mean all of a sudden!
    Cold Cold Cold not Cold!
    I searched and read about a few things that cause this but thought I'd seek advice.
    Obviously it could be low gas. I recently had the radiator and intercooler replaced, which necessitated removing the condenser and emptying the system.
    I would have thought that a leak would have the effect of reduced efficiency over time.
    Before I look into the compressor side of it, I was looking for an A/C fuse or relay, but I'm either a dummy or a there isn't one!
    I do have a HSE so it has rear A/C which I believe is a second evap but still only one compressor
    I put my Gap tool on and got the following results:
    System pressure 787.5kPa; Compressor /motor current 212A; Evap temp 37.0 although did reduce marginally over a few minutes; Ext ambient 32.5.
    I'm not sure what to think about the compressor current, that's stupid high, but maybe it's a gap tool thing.
    Thoughts, suggestions?
    Ralph
    Adelaide Hills. South Australia
    Is possible the Electro Magnetic Clutch has failed therefore while it is spinning, it may not be actually driving the Compressor. Wiring fault or blown fuse or a failed Clutch.
    NB. I am assuming the HSE has such a clutch assembly.
    No idea why you are getting partial operation unless the cause is intermittent.
    Brisbane,some of the time.
    I don't think the gas is gone at that standing pressure,if its correct.
    Unfortunately,the compresser could be shagged,not pumping,to stop suddenly,or an electrical fault thats stopping the compresser.
    There is an unloader valve that goes in them sometimes,but doesn't sound like yours has those symptoms,and my Indie told me they generally fail in the later 3.0L D4.
    Oct 2012
    UK cars the under car pipe work corrodes to rear AC and causes fail.
    Mar 2016
    Quote Originally Posted by Ralph1Malph View Post
    Hi All,
    Ralph
    There is no clutch. It’s a displacement compressor so a valve varies the output rather than a binary on/off of a clutch.
    2007 Audi RS4 (B7)
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    From what I've been able to ascertain the "compressor current" seems to be a vague interpretation of the displacement valve duty cycle. On mine about ~235 is flat out and it comes back to ~100 at lower loads.
    Your pressure matches your evap temp pretty much on the nose and the pressure is measured high side. Likely the displacement valve is jammed shut or the compressor is toast.
    Quote Originally Posted by DiscoJeffster View Post
    Thanks DJ, I am not familiar with this noo fangled stuff, but one lives & learns.
    Melbourne, AU
    I had poor and intermittent cooling on mine. Re-gas didn't fix, although gas was down a bit.
    Compressor replaced and running cold now. I was surprised at how bad it had become when it came back to normal.
    Happily done under extended warranty.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Quote Originally Posted by BradC View Post
    Thanks! Just as a matter of interest, is it 'easy' to replace a compressor?
    I know it won't be, but I do have one lying around and would be great if I could do it on a weekend!
    I have read that the displacement valve can be replaced as well. I better look into it!
    Ralph
    josh.huber Guest
    I'm pretty sure that's incorrect, but I will double check for you. Yes they have a valve to vary displacement or flow, but I'm 99.9% sure there is still a clutch on the front. The high low switch will generally control this and the ECM will control the displacement due to cooling requirements
