Results 1 to 9 of 9
Thread: Cut & Polishing a Car - Newbie Question
    Jul 2014
    Hobart, Tas
    Hi All,
    Bit of a newbie question. How do you cut and polish a car? Car in question has a bit of dull paint (slight oxidisation I think) and needs a tidy up for selling.
    What I know is;
    1. Wash car really well and dry thoroughly
    2. Carefully apply cutting compound and rub,
    3. Polish with polish and a buffer or by hand.
    I know it needs to be done under cover or at least in the shade and that all polishes are not created equal. I don't have any gear/polish etc and now is a good time to learn (as I might have some spare time coming up). (I have a Karcher, sponges, chamois for washing +drying)
    Can I get some advice on the full system, what to get, what to avoid etc. Also, is a buffer worth it or just hand polish?
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by 4xsama View Post
    Hi All,
    You have most of it. I would be wary of buffers, as most of the ones you see have far too high RPM and it is easy to burn through the paint, especially if you are a novice. I used to have a Rupes buffer and it only did 700 RPM max. God knows where that is now. Thing is, work slowly. Fast results are usually poor results. And remember, paint is measured in microns, so there ain't much to play with.
    This guy is probably a bit higher level for your needs, but he knows his stuff.
    YouTube
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Brisbane, Inner East.
    Depends on how badly deteriorated the paint is. If it just needs a cut and polish then good old Repo or Kitten No.2 is adequate.
    URSUSMAJOR
    May 2008
    Bundaberg Qld
    Do a bit of homework on the cost of having it done professionally. Might be economical given you may have to purchase tools/equipment and supplies to do it.
    4X4V8 Guest
    To get really good results depends on a lot of things - paint condition and thickness, equipment and polishes and your skill. You haven't said what vehicle you're selling or what paint is involved. A recent model car with pearl black paint is a lot different to old school white acrylic.
    I'm not by any means an expert but have been using an orbital buffer and Menzerna polishes to good effect for a while now with a few different vehicles I've owned.
    Best way to tackle it with minimal outlay to best effect is to get some claybar to remove pollutants, tree sap etc from the paint and then hand polish with a good quality polish, then wax. It will take you several hours to do properly and I haven't gone though all the steps involved. Should cost you less than $100.
    Ideally, you'd go for a good 240v buffer and pads, which is around $300 and up; add about $80+ for polish/waxes. Also a few $ for 2000-grit wet-and-dry sandpaper. And a lot of time to hone your skills. Probably not what you want to do here.
    If you're only interested in getting the car sold just pay the $400 or so for a paint correction if the paint can be saved or if you feel that's not worth it then just wash and dry the car. Cut-and-polish job as you described might work if an old acrylic solid colour but with a dark metallic might end up looking even worse.
    Jul 2014
    Hobart, Tas
    Quote Originally Posted by pop058 View Post
    Got a quote for $350. I think I'll go that way. Car goes under a cover until time to sell
    Ocean Reef WA
    I like to give ours a good waxing (Mothers something if my memory is correct) twice a year, if I was still a boy racer possibly more often......
    Washing is done when it's dirty or if we've been near the beach in which case the underneath gets a good bath, more water sprayed under there than on top. When flogging the Puma I got the bull bar looking good by using a black cut and polish stuff then black polish. Came up great but not sure how long the gleam would have lasted.
    AlanH.
    Oct 2012
    When polishing anything it is good practice to get some blue painters tape and tape off around any porous parts and trim where it butts against a painted surface.
    This is more so the D3 with unpainted black wheel arches and door handles. When the buffer (or even hand polishing) hits these items they show the polish scuff and it’s very hard to remove it.
    The tape allows you to polish right to the panel edge without fear.
    josh.huber Guest
    Perthdisco. I spent hours trying to clean my windscreen Jets and lower black door trims. This does the job perfect, I think I actually used to use the gold class one.
    But I like your prevention idea better then mine. Which has only been crap tape. I'll get some blue stuff.
    +1 vote for kitten no.2 especially for a chalky cut. Cheap as chips. Gets the job done.
    If you want a cheap cut and polish a second year apprentice from the local shop will be good at it. And cheap.
    I have all the right tools and achieve a level that is ok. I would never touch a hot rod etc. I've made to many learner errors. I like to machine polish if needed. But hand wax only.
    This backs up everyone else. Havnt used my machine for ages. Used it recently to do a super job of the roof before the rack went on.
    In my experience the difference between a machine polish and a hand polish is just time. Not quality. However a hand polish won't pull the paint of the car on your first offence. A machine polish will.
