Results 1 to 10 of 19
Thread: Anyone pulled apart a hinge?
    Apr 2018
    Victoria
    Hi all,
    I’ve pulled off my door hinges to replace the bolts and the hinges themselves are in surprisingly good condition so I’m getting them blasted and resprayed (powder coat).
    Question is if there’s any nylon or plastic in the hinge assembly? If so this will be destroyed in the firing process and I’ll be without doors... ☹️
    Thanks in advance
    Mar 2007
    Canada
    Depends on the year. Later hinges have plastic bushings.
    Apr 2018
    Victoria
    Quote Originally Posted by Red90 View Post
    It's a 1998 300tdi Defender.
    The hinges squeak like they're metal on metal so I'm hoping that's the case.
    There's a couple of tiny plastic grommets in the screw holes holding on the rearview mirrors but that's all the plastic I can see.
    I'm doing the same with the rear door hinges too so if anyone knows if they have any meltable parts it'd be much appreciated!
    Adelaide Hills. South Australia
    I guess you will soon find out like I did some years ago, when I took a bucket of metal stuff/bits from my S2A to to be plated. Got it back & found the Aluminum Hinge pins in the Vent opting mechs had dissolved in the acid bath that they didn't ask me about (my bad) & they fell to pieces & were lost in the bath.
    Good that you are asking though. Better to be safe than sorry.
    Wheelers Hill, Melbourne
    According to this article they are metal on metal, but from memory the pins are grooved.
    Defender door hinge upgrade
    Apr 2018
    Victoria
    Quote Originally Posted by 4bee View Post
    Ouch hope that doesn’t happen in this case 😳
    Apr 2018
    Victoria
    Quote Originally Posted by DeeJay View Post
    Thanks DeeJay, yeah I read that article before I had a crack at pulling them off. On close inspection you can see the bushes, and giving them a cut with a knife they are certainly metal but I wasn’t sure if there was some other hidden plastic mechanisms inside and I wasn’t quite ready to knock out the pin to find out...
    SW of Geelong
    You can remove the pins, which would be better for the finishing process.
    They are splined on on end.
    Drive them out with a long nose punch.
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Jan 2012
    Geelong
    No plastic on Tdi hinges as far as I'm aware, td5 onwards have nylon washers to stop that metal on metal action. Perhaps you remove the pin and could take a bit off with a file or whatever and fit a nylon washer in between to give them a longer happier life!
    preston
    While the front hinges are off, pressure wash the firewall out and paint the cavity with rust converter/sealer.
    I use slightly thinned/warmed fish oil.
    Use a kero Gun at 100 psi.
    It will mist clear out the other side and every hole👍👍
