Results 1 to 10 of 16
Thread: D3 2.7 coolant leak
    Oct 2006
    canberra
    D3 2.7 coolant leak
    So I'm chasing a coolant leak on the left hand bank can't see any sign of leak from above from the egr cooler or hoses from underneath its driping down on the diff and it's all over the back of the ac compressor so it's coming from above that had a feel around the bottom of the water pump and that seems dry there I'm at a bit of a loss as to where it's coming from any ideas?
    Jul 2016
    Blackstone
    The plastic coolant housing under the throttle body?
    For some reason it is called the thermostat housing but doesn’t house the thermostat???
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    Oct 2006
    canberra
    Quote Originally Posted by SeanC View Post
    That was the first port of call and it's good it's around the egr cooler but just can't spot it
    josh.huber Guest
    It's likely coming from where the coolant exists the block on the left hand side of the engine. The alloy heat shields near the wheel need to be removed to see it. It's a **** job.
    I have a spare oring here I can send you. Did you change coolant recently??
    Oct 2006
    canberra
    Quote Originally Posted by josh.huber View Post
    Yeah new coolant in it is it a bolt on fitting with an oring? Bottom hose goes to it?
    josh.huber Guest
    Quote Originally Posted by 460cixy View Post
    That's the one!! What coolant did you use
    Oct 2006
    canberra
    The red coolant. Do you know what the outlets called or a part number I found it on a diagram but no part number I dunno if I could really be bothered digging in there you can't even see where that bottom hose goes to its crap. Edit I found it and of course it's plastic ****
    josh.huber Guest
    If you need the oring I can send you one. If it's the same as the 3.0l it's a **** job but I've done it in a 3.0 with the compressor in place.. takes a lot of wiggling
    josh.huber Guest
    What brand?
    Oct 2006
    canberra
    What brand?
    Ile get a genuine one
