Results 1 to 4 of 4
Thread: O-Ring (head side) on Oil Supply Line going to Vacuum Pump
    sadil Guest
    Hello,
    I was wondering if anyone knew the specification on the O-Ring found on the vacuum hose oil supply line, on the head side. The crimping fitting has a threaded nut, but the hose fitting lip has an O-Ring. I have no found this O-Ring as a service parts and it seems like I would have to buy a new hose. I dont mind buying a hose but availability is difficult from UK on parts.
    YKL100120- Vacuum pump - hose (Vacuum pump - hose - tube) - - Land Rover Defender 130 2.5 TD5 diesel 122 bhp 1998->2006
    Hose shown above. O-Ring you can see comes installed. The service manual says to discard this o-ring as well and mine is torn in two. I just dont know what to replace it with.
    Thanks!
    Narre Warren South
    Quote Originally Posted by sadil View Post
    Hello,
    Thanks!
    Take the hose to an O-ring supplier and they will come up with something suitable.
    Someone like this
    O-Ring Seals - Hardware - Grainger Industrial Supply
    Best of luck,
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    sadil Guest
    Was really hoping to get lucky with someone knowing the size. Sizing an o-ring, haven’t done that before. Simple as taking OD of male side and ID of female side? Engine oil sealing should be straight forward?
    Narre Warren South
    My local O-ring supplier prefers to see the parts rather than match an old O-ring.
    Engine oil sealing no problem, remember Land Rover don't make O-rings they buy them from an external supplier.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
