Results 1 to 10 of 13
Thread: Installed APT Front Guard and Air Compressor Guard on D4
    Apr 2020
    Added some APT underbelly protection to the D4:
    Before:
    After:
    Install notes:
    Front Guard Install.pdf
    Air Compressor Guard Install.pdf
    Naps
    MY16 D4 SDV6 HSE 3.0L MOAB 265/60R18 KO2 - Carbon 12K Winch - DO 35 Hitch - RedARC TowPro - Rhino Rack Backbone & Pioneer Platform - Front Runner Ladder - 100Ah 'The Lithium Box' - Full Boar Fourbie Drawers & Travall - APT Front/Sump/AC/Sliders - Safari snorkel - Oricom DTX4200 - Cel-Fi - GAP IID - TyreDogs
    May 2009
    St Agnes, SA
    I did the same, but the full set up.
    Since fitment there have been a few occasions it has been called into use.
    Just need a aux tank guard and Il be set..
    '15 Discovery 4 HSE- The family bus and the kids like it!
    '89 RRC- My favorite of the bunch!
    Ex '03 Commodore 'S' ute- 450hp of uncracked 5.7lt and 6 speed manual uteness - Still crying that its gone
    Ex '06 GLXR Triton- *Gone and forgotten*
    Apr 2020
    APT Sump Guard
    I have now added the APT Sump Guard. The curious thing is that it has a hole for the sump plug access (matching that of the original LR plate) but neither of them actually align to provide access to the sump in any case. At least that is my view of it.
    Nov 2015
    Black Rock
    Quote Originally Posted by Naps View Post
    You don't need access to the sump plug. I thought the hole was an inspection hole anyway, but I'm only guessing. Oil changes are best done by the vacuum extraction method as designed.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Apr 2012
    Whyalla, SA
    The hole is purely to allow visual inspection
    Apr 2020
    Thanks for the clarification... I will have to follow up on the vacuum extraction process. As for the inspection hole...not sure what you would be looking for...oil leaks?
    Sep 2014
    Baldivis WA
    Inspection of what? To me its a drain hole for water, mud etc. Theres nothing to "inspect" at that point and the hole is too small to see anything anyway. The steel belly pan fitted with my ARB 'bar and the factory plastic "guard" for the transmission also has similar drain holes.
    APT is good gear, still have the rocksliders on my wishlist....
    Jun 2020
    I was advised not to bother with the sump guard because the factory metal plate under the engine is already tough enough...?
    Sep 2014
    Baldivis WA
    Perhaps, but imho the tranmission bash plate is a plastic one that is not suitable for anything but light gravel rash protection on unsealed roads.
    Apr 2020
    Quote Originally Posted by Eric SDV6SE View Post
    I agree Eric, I couldn’t see the purpose of the hole or what you would be looking for...it is most likely a remnant of the past. As to the toughness of the factory sump plate...it did look to be reasonable, but it is all relative to what it may bash up against. One area not to neglect is the Air Compressor and the APT kit is worth looking at. Ben has put together some informative install videos for all the kit APT Offroad
