Results 1 to 3 of 3
Thread: charging issue - sort of...
    Jan 2020
    McGowanastan
    Gday All,
    I have been having a strange issue over the last couple weeks with my charging system on the D3. Upon starting the car sometimes the alternator will start charging straight away , but sometimes the battery light will remain on and for up to 3 or 4 minutes there is no charging occurring at all.
    The alternator was replaced about 5k ago with a new denso OE unit, and once it starts to charge it will continue to do so without issue no matter how long you drive for. I have only recently ie a week ago fitted a new battery so would assume that cant be the fault , as it had occured with my old battery which was 5 yrs old and only showing 550CCA on the load tester .
    Anyone heard of this or had it happen , and if so what was found to cause it. I am thinking of removing the alternator and checking all the connections are ok and tight , but have had my hand at the back and cant feel anything obvious.
    Bulletman
    Apr 2012
    Whyalla, SA
    Check your battery terminals.
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Did your charging make a miraculous recovery or did it end up dying because it was terminal?
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
