Results 1 to 10 of 16
Thread: ARB Compressor under Rear Seats D3
    Apr 2013
    Darwin
    Godd evening team- I am contemplating mounting an ARB twin compressor under the rear pass sid seat. Seems to be enough clearance and can get a mounting plate made.
    Has anyone put one there or had experience (good and bad) with placing one there? Seems to be a convenient and unobtrusive location
    I have a D3S on coils and going to put a factory airtank on for on board air as well so proximity is good also.
    Russell
    We ran a single cylinder ARB unit under the rear seat of a GQ for years without any issues.
    The twin cylinder naturally produces more heat so cooling will be an issue to consider...they have a fan and thermal cut out don't they?
    ....I know they are darned heavy!
    St Helena,Melbourne
    1.13 MB
    If you have a 7 seater i would consider fitting under the middle seat so its not in the way when getting into the rear seats, you can still run the the hose connection point close to the door opening.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    I would be concerned about the heat - I have two different compressors and both will burn skin when at normal operating temperature.
    Son's mate has one in the storage metal box behind the Perenties seat which also has some gear in it meaning the air space around the ARB is quite small. There's also no direct air flow and so far so good. Guess it will cut out if it gets too hot.
    Mornington Peninsula, Victoria
    A mate has his compressor in the exact location you speak of. No issues & he's happy. He's done loads of remote touring also. Hope this helps.
    Jul 2012
    Perth- South of the River
    This is where mine is going, when I get around to mounting it. I've got an ARB and and old Blue Tongue that I'm going to set up together in a sort of ARB Twin/Twin Tongue Frankenstein's monster creation....
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Dagilmo View Post
    Just be aware of the height in case you need to drop the seat down as you don't want to short out some wiring.
    1974 VW Kombi bus
    Nov 2011
    East Gippsland
    The other place to put a single cylinder ARB air compressor is in the engine compartment, on the passengers side, between the battery and the headlights. There are some M6 or M8 threaded inserts that a home made bracket can be made to fit.
    There are photos on AULRO or I can take one if necessary.
    Peter
    May 2012
    Tingha NSW
    ARB compressors
    Quote Originally Posted by kodakman7 View Post
    Russell
    This may be useful:
    ULTIMATE 3-WAY ARB Air Compressor Comparison {YOU WON'T BELIEVE THE RESULTS} - YouTube
