Hello
So I have a 2005  Discovery 3 TDV6 - had it since new.
About a month ago I started getting "suspension faults".
With the IID tool  - these were the faults
- C1A13-64 (28) Pressure does not decrease when venting gallery - Algorithm based failure - signal plausibility failure
- C1A20-64 (AF) Pressure increases too slow when filling reservoir - Algorithm based failure - signal plausibility failure
Finally - it became almost undrivable with almost no air available  (disco 3  is a really uncomfortable drive on the bump stops !)
Some internet and forum research indicated the less likely to be the valve and more likely the desiccant canister is blocked. The filters are probably full of dust from the desiccant breaking down. Air passes in and out through the canister so the air down is probably struggling to exit.
So - fifteen years  and 189,000 km, I seems I need to service the compressor  - have ordered  a kit  from 4x4airseals.com  along with a complete o-ring kit for all the solenoids.
But in the meantime - I got a tip from a fellow forum member that there are some "cheap"  Hitachi compressors on eBay
Air Suspension Compressor Pump For Land Rover Discovery 3 Hitachi Type LR023964 6941503307842 | eBay   which I have now ordered one.
Plan is to swap out the genuine compressor with the cheap one, to get back on the road then spend my time doing a full refurbishment on the OEM compressor, then swap back . 4x4airseals.com have some great videos.
Will then also have a spare compressor.
Long story,  but for your original question, 15 years with no maintenance is pretty good - maybe it could have been avoided if I serviced at 10 years and replaced desiccant, but who knows - have not seen any mention in the service manual, maybe LR  thought those in heavy use would burn out the motor an be replaced, before the desiccant , went to dust.
