Results 1 to 9 of 9
Thread: Steering column knock
    Feb 2017
    Riddle me this Batman ..
    2016 D4 TDV6. 80,000kms. Full bash plates and rock sliders underneath incl on LCA’s.
    Perfect feel when on road or easy off road. However - a distinct knocking feeling felt (not heard) up through the steering wheel when on sudden bumps or corrugated roads.
    Fairly sure it’s not LCA’s as I’ve had a previous D4 which had LCA’s replaced and this def feels different.
    Feels rack / steering related.
    Anyone got any ideas?
    Mar 2016
    I’m sure it will be LCA’s - mine didn’t feel the traditional way they fail but they were. Same symptoms as you describe.
    2007 Audi RS4 (B7)
    Brisbane,some of the time.
    Quote Originally Posted by DiscoJeffster View Post
    Mine did that for quite a while, then the knocks gradually started over the larger bumps, particularly going slower, say less than 60km/hr.
    I had similar symptoms recently also. Was an upper control arm and front sway bar link.
    Very noticeable through the steering wheel on small rocks etc off road, but on road and generally felt fine.
    Feb 2014
    Adelaide
    Mine is the same and I too don’t think it is LCA as there is no knocking under heavy braking. I have a little play in my steering wheel also when stationary I am going to have a crack at replacing the lower steering shaft the knuckle joint can ware and cause issues as mentioned.
    2010 D4 3litre twin turbo brand new motor 5km old on a 100,000km car. Kaymar rear bar, ARB front bar, Hannibal roof rack, Hella Predator Spot lights, long rand fuel tank, Traxide battery management. touring weapon.
    Sep 2014
    Baldivis WA
    Front and rear sway bar mounts will be shagged. Replace with oem rubber. Tried the poly, too harsh. I fitted super pro adjustable rear links at the same time, reduced length by 8-10mm, makes for better towing and cornering stability.
    St Helena,Melbourne
    1.13 MB
    Check the steering UJ, could be loose.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    LRD414's Avatar
    Oct 2014
    Quote Originally Posted by Eric SDV6SE View Post
    Can you tell by inspection whether sway bar mounts are shagged?
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Sep 2014
    Baldivis WA
    Sorry, I should have been clearer, the sway bar rubbers will be worn out. You can tell by inspection if the rubber is flared out from under the mounts, and if theres a gap between the sway bar and the rubber, typically at the top. The rubber bushes are cheap as chips, easy to replace except for the passenger side front, but wouldnt be a landrover otherwise...
