Results 1 to 9 of 9
Thread: Auto flush with Valvoline?
    Feb 2016
    New Zealand
    35.44 MB
    Hi guys,
    I want to do the auto flush on the v8 d2 and change the filter. I was going to do several changes of oil and the advise here after doing a search seems to favour using Penrite ATF FS oil. However Penrite per 4 litre is rather expensive here in NZ compared to Valvoline Maxlife Multi Vehicle ATF which I can get in a 20Litre.
    So Is the Valvoline ok to use or am I being a cheap skate? The Valvoline does say it's good for Dexron3H, but I don't know what the "H" stands for?
    Cheers, James NZ
    '00 D2 V8 The orange off road truck. 2" lift, made my own rear bumper, still working on the front one
    '03 D2a TD5 The silver on road daily driver
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by James NZ View Post
    Hi guys,
    Cheers, James NZ
    GM licensed Dexron in various forms. 3H is merely a license, but it does signify certain modifiers that do such things as reducing foaming.
    Most of us have personal faves for oils. Mine is usually Penrite, but Valvoline has been around forever and is usually ok.
    You say you are doing a flush? Use the cheaper oils for that, but make the final fill one of the better oils. There are folk here that swear by various synth oils. I'll let them chime in.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Feb 2016
    New Zealand
    35.44 MB
    Quote Originally Posted by Tins View Post
    Hi Tins, thanks for the quick reply and good idea about the cheaper oil. I have some Aegis auto fluid, bought a 20L ages ago, but its a mineral oil and I read here that synthetic was the better choice.
    I'm being a bit cheap cos I have to spend more money on the car and there's only so much of it to go round
    Jul 2009
    I used to run the Penrite FS but have recently found myself having to rebuild my 4hp22. Shortly after, I've read that 'some' (sorry, a lot was excessive and typing quickly on the phone) of people of late are finding it burning up easily in the box and causing failure. Not sure I'll go back to it to be honest - might try something else.
    Last edited by Mutley; 23rd February 2021 at 01:15 PM. Reason: Correction of language
    NSW far north coast
    The full syn will have a longer service life than a mineral oil, and withstands oxidisation from elevated temps better than a straight mineral based oil, but no oil will protect from chronic overheating, and the 4HP22 in the D2 is marginal for size and cooling for towing use.
    The full mineral oil will be fine if you don't tow and stick to standard or less service intervals
    Feb 2011
    Hobart, Tasmania, Australia
    Quote Originally Posted by Mutley View Post
    Shortly after, I've read that a lot of people of late are finding it burning up easily in the box and causing failure.
    Where have you read this? Got a hyperlink for us please?
    Jul 2009
    Quote Originally Posted by twr7cx View Post
    Was on a LR bookface feed. I'll try dig it up if Mr Zuckerberg doesn't classify it as news and hide it on me...
    Apr 2012
    Whyalla, SA
    I used to run the Penrite FS but have recently found myself having to rebuild my 4hp22. Shortly after, I've read that a lot of people of late are finding it burning up easily in the box and causing failure. Not sure I'll go back to it to be honest - might try something else.
    Please do post link.
    What’s a “lot of people”?
    People burning up the box is more likely that the cooler is now 15yrs+ old and caked solid causing overheating.
    Apr 2015
    Hervey Bay
    I use the Max Life ATF in everything. First came across it 10 years ago when I was looking for suitable oil at a reasonable price for my XJ8 Jag with a ZF 5 speed. Since then I have used it in a D2 V8, Freelander 2, Range Rover L322, RRC, Mitsubishi Sigma (manual), 74 XJ6 Jag (BW65) and Leyland p76 (BW35) and it's been great with no issues. It's cheap too, in Australia we can get it from Bunnings for $35 for 4L.
    The D2 ZF 4 speed only requires Dex III so the full synthetic of the Max Life ATF is a step up.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
