Thread: Unrelated Electrical Issues.
    May 2015
    Williamstown, Victoria
    I have a Disco that suddenly requires locking and unlocking to start the engine. Also the HVAC unit has to be turned on each time. And the Nanocom will not boot up. The Nanocom boots up on a USB at home.
    No radio or clock, same fuse I know, and I have replaced the fuse. Tomorrow I plan to go to the local RepcoSupercheapAutobarn franchise and buy some fuses, just in case.
    What fuse supply's the data port?
    This may have started after the cigar lighter fuse blew, due to a dodgy USB charger unit. Or maybe not!!.
    I may also need to buy a TC LED as boy did that get a work out over the weekend!!
    Build date 11th Oct 2003
    LROCV #1410
    May 2015
    I have just unlocked the car. The internal lights do not go on. When I lock the car, the red dash light flashes very fast.
    LROCV #1410
    Jul 2014
    west of Transylvania
    F20 or if it's good then something on that circuit
    May 2015
    I am a Wally!
    I have just had a look at fuse 20, it is half in and out. The left hand blade in in the right hand socket. A dumb error. Every thing is working properly now.
    I think that the radio installer has used the radio memory supply to power the radio, hence the radio not working when the fuse was not in properly. As well as all the other bits.
    LROCV #1410
    Back down the hill.
    Quote Originally Posted by Bohica View Post
    I wish all my automotive issues were "dumb errors", they're economical rectifications.
    May 2015
    Quote Originally Posted by V8Ian;[URL="tel:3069416"
    3069416[/URL]]I wish all my automotive issues were "dumb errors", they're economical rectifications.
    Yes I concur. I no longer go to Toolangi as it costs too much to fix up the car afterwards.
    LROCV #1410
    Sep 2010
    The Hills.
    152.79 MB
    Not the Disco's fault you broke your Nanocom.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
