Results 1 to 10 of 15
Thread: Clunky front end
    May 2016
    Flemington Vic
    Clunky front end
    Hi All,
    My 08 Disco has about 220,000 on the clock and is going strong.
    My front end is starting to sound clunky and sharp, it’s like the airbag shocks are not as soft as they once were.
    I’ve made a visual inspection of the control arms and bushes etc when I do my oil change and they all seem fine.
    My question is do the bag shocks eventually become less effective and need replacing?
    I replaced my air compressor a while back so no issues there.
    Any thoughts appreciated.
    Apr 2012
    Whyalla, SA
    Shocks lose their effective damping from around 100k abs degrade from there.
    The clunky sound will be rear lower bushes and/or ball joints, my money is the lower rear bushes.
    At the age of vehicle start planning a midlife on the suspension. Arms and strut assemblies.
    Jul 2012
    Perth- South of the River
    x 2 for the lower rear bushes. For clarity: Lower Control Arm (search LCA for reams of information on here) rear bush.
    I've just done mine at 110k km. Hash ride, a bit of knocking but main symptom was shuddering whist braking. New bushes and all resolved.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    Nov 2019
    Tasmania
    Sounds like blown lower control arm bushes, these are a hydra bush filled with oil, over time the rubber perishes and the oil ends up leaking out and then you’re left with a clanking front end… replaced both mine 25k km ago and front end feels smooth again. There’s lots of threads on here that cover the subject and also how to replace yourself if you’re interested. 👍
    Mar 2020
    Brisbane, Qld
    Quote Originally Posted by MuzD4 View Post
    Yep, I also agree with everyone here. Had mine done at 100,000km (roughly). Really tightens up the front end and feels great to drive again. As with most things LR related though it stung the back pocket.....
    josh.huber Guest
    Quote Originally Posted by LukeO View Post
    It doesn't have to but, I did a tutorial on here years ago. Including buying a new press was less then $500 basic hand tools only required. Back then I burnt the old Bush out. I use a drill these days
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by josh.huber View Post
    Ora press kit for less than $200.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2013
    Universe A
    I made my own tools, bit rough though! What is this kit you are referring too?
    josh.huber Guest
    Im always looking but never find em that cheap. Show me the way!!
    Nov 2019
    Tasmania
    I bought the Laser LR bush tool (part number 6180), cost me ~$400 (banking on using it a few times between myself and another mate) - easy to use and worked a treat for me!
    6180_Instructions.pdf
    Parts cost me;
    LCA rear bush (oilfilled) OEM $88.36ea +GST
    Bolt kit for LCA$53.03 +GST (each side)
    Note: the following made my life easier for this task;
    • GAP IID tool - used this to drop/unload/release suspension (need to do this to allow free suspension movement)
    • Car hoist
    • Vertical jacking prop (made it easy when setting LCA to normal loaded ride height [which I measured with car on ground] before tightening bush bolts, to ensure bush is unloaded at standard ride height)
