Results 1 to 10 of 11
Thread: Rear work lights. Anyone have them?
    shayne86 Guest
    As the title suggests, does anyone have some rear work lights mounted on their disco?
    I've got left over unused led lights from the old dual cab i want to put on the rear gutters just above the door.
    I'm a little unsure how to get the wires into the cab though? This stuff was easy on a dual cab. Plus I'm stuck at work (thanks covid) so can't simply go out to the shed and look.
    Any hot tips from anyone who has something similar? Ide like to avoid drilling holes in the roof but if thats the only way then so be it
    Apr 2012
    Whyalla, SA
    Drill a small hole in the back corner below the gutter, drop down internally to lower grommet at tail light.
    Will look tidy and neat.
    shayne86 Guest
    Ok cool. I'll check that out when I'm home in a week. Haven't had a chance to look behind the trail lights yet so sounds like a good excuse to put new globes in while I'm there
    Jan 2017
    Geraldton WA
    Why not simply turn the rear interior light on
    4.6m Quintrex boat
    shayne86 Guest
    Quote Originally Posted by trout1105 View Post
    Doesn't quite have the same throw about camp
    Oct 2020
    Elizabeth North SA
    3.15 MB
    Mine are mounted on the cargo rack and have the cable run down one leg, run along the gutter to the front driver side and under the a pillar cover into the engine bay where the relay is.
    shayne86 Guest
    Quote Originally Posted by johnp38 View Post
    Yeah that's what i would to, but no roof rack yet
    Aug 2013
    Rockhampton, QLD
    Initially I was going to do the same, In the ended I did this as I didnt want to drill the body. The cable runs under the door behind the tyre.
    2003 D2a TD5 Auto
    1960 Series 2 Petrol
    shayne86 Guest
    Quote Originally Posted by singlecell View Post
    Hey that's a cool idea! Could almost squeeze a cable through the hole for the rear wiper fluid line.
    Aug 2013
    Rockhampton, QLD
    Quote Originally Posted by shayne86 View Post
    Definitely some better ideas on how to run the cable than the way I did. But it was getting late by the time I got to do the wiring and I just wanted to job done. Ill sexy it up one day.
    2003 D2a TD5 Auto
