Thread: Rough idle after battery disconnected?
    shayne86 Guest
    Had the battery discontented for a few hours the other day. Now the car has a very rough idle. Is this normal?
    Car starts fine and runs fine for about the first 15-20 seconds then sounds like its got a lumpy cam. Responds ok-ish when driving but feels a little hesitant.
    Nothing like it was yesterday before i had the battery disconnected.
    Is a v8 for reference. 2004 model.
    Anyone come across this before?
    shayne86 Guest
    Tried to run it with the MAF plug disconnected and it idles fine!
    Surely it can't be a bad maf sensor, this one is only 4 months old?
    shayne86 Guest
    For reference i disconnected the battery only. Nothing else was touched under the bonnet so couldn't have damaged anything or knocked anything like the MAF. Weird
    Back down the hill.
    Is the MAF genuine or aftermarket?
    shayne86 Guest
    Not too sure to be honest mate. Its a Bosch unit from a reputable supplier here in Perth. Not an ebay item.
    Back down the hill.
    Bosch should be OK.
    shayne86 Guest
    Bosch should be OK.
    That's what i thought. Hence why I'm so confused
    shayne86 Guest
    So ive cleared a code through my obd2 reader and seems to be back to normal. Will see how it goes in the morning
    May 2015
    Williamstown, Victoria
    What was the code?
    Build date 11th Oct 2003
    LROCV #1410
    shayne86 Guest
    Quote Originally Posted by Bohica View Post
    What was the code?
    Can't remember. Something about voltage to maf low.
