Thread: Stiff rear passenger door.
    May 2015
    Williamstown, Victoria
    The door is quite hard to open and close. The others are fine. Is this a simple lube job (WD40, oil grease) on the hinges?
    TIA
    Julian.
    Build date 11th Oct 2003
    LROCV #1410
    Perth WA 6149
    Also look at the door stop under the door.
    Steve
    Sep 2018
    Travancore
    Hinge lube
    Have had a fair bit of success with Silicon lube for sticky doors - WD40 didn't seem to work for too long whilst the silicon lasted.
    2004 Discovery 2a TD5 Auto Aspen Green AKA Robin
    2000 Discovery 2 TD5 Auto Alverston Red AKA Edward
    1997 Discovery 1 TDi Manual White - Gone but not forgotten
    1994 Discovery 1 V8 Auto - Gone once it consumed half the worlds resource of oil
    Apr 2016
    Country Vic.
    Quote Originally Posted by Rok_Dr View Post
    Steve
    I think the door stay/stop/strap for the rear pass door is in the middle of the door, not under.
    Rear load/tailgate door is under for sure.
    Give it anything just to see if anything helps .. even just a small drop of oil. Hinges too of course.
    if it doesn't help, could be that the door stay may have collapsed a bit too.
    As RRT said, I also found silicon spray a bit more longer lasting and effective.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jan 2011
    Gippsland
    I carry a can of spray lithium grease and use liberally on all hinges and the door latch mechanisms. And having a rear cargo barrier and no access to the internal handle I pay special attention to the troublesome (for some) rear tailgate latch mechanism - and have never had an issue with it. 🤞🏽🤞🏽
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
