Results 1 to 10 of 14
Thread: Slow coolant leak
    Mar 2016
    Slow coolant leak
    I seem to have one. Losing coolant slowly over time. I can smell it when the engine is turned off but I can’t see the telltale signs anywhere. Losing around high to low on the bottle over a month or two.
    I was thinking egr but then I’d not thought I’d smell it. I previously replaced the crossover when that bleed failed so it’s not that.
    No drips, obvious leaks.
    I guess I need to take it in and get a pressure test done.
    2007 Audi RS4 (B7)
    Jun 2013
    Universe A
    Quote Originally Posted by DiscoJeffster View Post
    Have a look passenger side next to the turbo through the wheel arch.
    josh.huber Guest
    Quote Originally Posted by shack View Post
    That leak will be visible on top of the AC compressor, Check your radiator cap and bottle. My aftermarket cap was leaking and caused the same issue. I've got a new genuine bottle and cap to go on. I pressure tested it and it held over a weekend
    Oct 2012
    Check also plastic bleed screw on crossover pipe at back of motor.
    Mar 2016
    Quote Originally Posted by josh.huber View Post
    Bottle isn’t leaking. Genuine cap. Leaks there are obvious as the coolant leaves a lovely trail.
    2007 Audi RS4 (B7)
    Mar 2016
    Quote Originally Posted by PerthDisco View Post
    As per original post, coolant crossover is new and bleed screw new after previous failure. Thanks anyhow
    2007 Audi RS4 (B7)
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    The vacuum fill kit I bought comes with a manual pressure tester also, you're welcome to come and grab it if it'd help.
    My experience with pressure tests is it's often much easier if the cooling system is empty. Then you can run around with a bit of pipe in your ear and the other end scouting around looking for the leak (listen for the whistle).
    When I had the slow leak in the D3, it was a pinhole in the EGR cooler supply hose right under the intake elbow. It took quite a while under pressure and looking around with a torch and borescope to spot the spray.
    Mar 2016
    Thanks Brad. As a groper (sandgroper for those who think I’m inappropriate) I might take you up on it. I’ll wait until coolant comes on special and do it all at once. New Meyle bottle in the garage ready to go.
    2007 Audi RS4 (B7)
    Dec 2009
    Baldivis WA
    I’ve also got a coolant smell and a very slow drop in coolant level on mine. Nothing obvious from above or below, but it started after I had the timing belts replaced. So in my case I suspect a small weep from the coolant manifold ‘O’ into the head, I replaced the coolant manifold (Including the ‘O’ ring) 6-12 months before the belts were replaced.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Supporter
    Mar 2018
    Perth (near Malaga)
    I accidentally bought a set of Coolant outlet to head O-rings when I replaced mine last time, not realising they come with the outlet. So I have a spare set if you need them. I don't have the coolant outlet to oil cooler O-ring.
