Results 1 to 3 of 3
Thread: Auto Gearbox Oil Change
    Apr 2017
    Maitland (ish) NSW
    Changed the oil in my auto yesterday just as normal maintenance and as I was pouring the old oil in to a waste container i noticed what seemed to me to be quite a lot of debris in the oil, should I be concerned.
    The gearbox has given no trouble at all and shifts nice and smooth. The oil I use is Castrol DEX III and have done around 7-8 oil changes since I've had it over the past 4 years. Its on a TD5 with 250k on it and i have just recently had a mild tune put on it (thanks TD5ZILLA) I don't normally tow anything bigger than a small trailer but have a 2-3 ton boat to move on the weekend. Any info would be much appreciated.
    Mark
    Discovery D2a 2004 TD5 auto (current)
    Discovery 1 V8 1996 manual (gone)
    Various series Land Rovers before moving to OZ
    Nov 2014
    Nirvana near Albany W.A.
    looks like clutch material, either from clutch packs or torque converter clutch.
    might be worth even more frequent services so you can keep an eye on it.
    hopefully the tuner has mapped to be kind to the auto on changes.
    Worth using full synthetic if tuned and/or towing
    I use penrite atf/fs.
    Apr 2017
    Maitland (ish) NSW
    Thanks discorevy will give it a full service with new filter and maybe change the fluid to fully synthetic. The tune is on the mild side to be able to tow with the 32” tyres, I’m not towing on a regular basis.
    Is there a way of removing all the fluid in one go or is it a matter of doing 2 or 3 changes until the fluid is clean.
    Thanks for any info
    Mark
