Results 1 to 9 of 9
Thread: Rust in the gutters, roof losing clearcoat.
    May 2015
    Williamstown, Victoria
    To fix the rust, I plan too sand off the rust, then primer coat, then top coat. The colour will not quite match, but as it is a not easily seen area, not an issue. I have Chawton White touch up paint, but it does not match after 18 years of sun. I am not using rust remover, it does not seem to do a good enough job.
    The clear coat on the roof has come off in two spots. How do I fix this? Acrylic clear coat spray can?
    How do I hold the can upright to spray the roof? Tie the winch bar to a crane and lift?
    Build date 11th Oct 2003
    LROCV #1410
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    just vinyl wrap it .It'll look like new
    Sep 2018
    Travancore
    Quote Originally Posted by Bohica View Post
    Mine has come off in two spots as well on both the D2's, front and back...
    2004 Discovery 2a TD5 Auto Aspen Green AKA Robin
    2000 Discovery 2 TD5 Auto Alverston Red AKA Edward
    1997 Discovery 1 TDi Manual White - Gone but not forgotten
    1994 Discovery 1 V8 Auto - Gone once it consumed half the worlds resource of oil
    Sep 2018
    Travancore
    Looked at this but it would appear that the wrap is not wide enough to cover the roof?
    May 2015
    Quote Originally Posted by RRT View Post
    The people that put on the warp, will not work on a car with buggered clear coat.
    This is beyond my skill set.
    I think spray can, then 1200 -1500 grit wet and dry, and then polish/cutting compound.
    LROCV #1410
    Back down the hill.
    Ask Epic Dragon, she's a time served automotive spray painter.
    May 2021
    Mackay
    White's super easy to blend. My old Patrol was about seven different shades of the stuff as it got to the point I'd just through any white I had on it when needed and you'd need to be looking for it to notice. The technique is not to have hard edges unless it is meeting a hard edge, but to progressively feather each new coat of paint progressively further into the original finish.
    Clear coat is a PITA. It's no doubt flaking away at the edge, so it needs to be sanded and feathered back to good stuff whilst doing as little damage to the base coat as possible - not easy!
    And before you go all "Gods must be crazy" to spray the roof, a lot of modern pressure pack sprays can be used in funky positions without issue and most should have a rotatable fan on the nozzle to allow setting between horizontal and vertical. Worst case scenario is use the fullest cans you have for horizontal surfaces.
    Sep 2018
    Travancore
    Roof
    Suppose that even with a bit of orange peel you are not going to see it. Quite like the idea of painting both my roof's white in the traditional LR colour scheme way and just paying strict finishing attention to the sides lol.
    May 2015
    The part cannot be seen from the road. I do not plan on getting orange peel. If I do, just buff it out.
    LROCV #1410
