Results 1 to 10 of 14
Thread: D4 rotors and pads recommendations
    Travelling (NFA)
    Wanting to change the rotors and pads on my 2013 D4 SDV6 and looking for recommendations as to which brand are worthwhile.
    Had in mind the'4x4 Survival' heavy duty rotors and pads as I need an emphasis on towing.
    I know rotors/pads vary quite a bit in pricing, but I'm not necessarily after the best .. just something better than OEM.
    I'll probably just start off with the front set first.
    I've had the '4x4 Survival' on my D2 for some years and found them to be quite good.
    Is it worthwhile going ceramic?
    I'm open to suggestions.
    Mar 2016
    I have imported Akebono ceramic and used RDA rotors. I’m extremely happy with them. Zero dust, great stopping.
    I’m told the Peders ceramics are the same as Akebono.
    2007 Audi RS4 (B7)
    josh.huber Guest
    Quote Originally Posted by DiscoJeffster View Post
    Im the same as jeffster, get the rotors locally and the pads from RockAuto
    Cheapest I've ever found
    Apr 2007
    Newcastle NSW
    Are the Akebono pads (EUR1479) suitable for the larger front discs for the SDV6? As opposed to the smaller rotors for the 2.7 motor?
    Goldey
    Just arrived: 2012 D4 3.0 HSE, the journey begins again ;-).
    Gone: 98 Disco 300tdi Auto, and some extras
    Apr 2012
    Whyalla, SA
    T2 or T3 DBA rotors
    Ceramic Pads (Akebono are the pic of the bunch)
    Mar 2016
    Quote Originally Posted by goldey View Post
    Goldey
    Yes. I use them on the front of my 3L. D4 rotors and pads recommendations
    2007 Audi RS4 (B7)
    Melbourne, AU
    DBA rotors and TRW ceramic pads. Excellent braking and no dust.
    Bought the pads from Advanced Factors in UK a couple of years back and they don’t appear to be available anymore. Will likely try Akebonos next time around.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Travelling (NFA)
    Quote Originally Posted by josh.huber View Post
    I checked out Rockauto and they only list the LR4 in a 5.0L V8 (US)
    As far as I was aware, they have different rotors/pads ... but I might be wrong.
    Mar 2016
    Quote Originally Posted by rapserv View Post
    As per others replying here, if you have the 3L then EUR1479 is the pad you want.
    2007 Audi RS4 (B7)
    May 2010
    Brisbane, QLD, Australia
    I went non OEM a few years ago and used a mechanic I'd known for years. He doesn't do a shed load of European cars so he uses a company that recommends and supplies parts that can be used as an alternate.
    I ended up with RDA rotors (RDA7468D Slotted) and non OEM pads (Not sure what brand - receipt only quotes a generic part number). I experienced brake fade under heavy braking .... coming down through hill country for example. Within a week I started developing a shudder. This progressed to the point that the car was almost undrivable. No questions asked, the mechanic replaced the rotors but to no avail, as I had the same problem within a few days.
    I'd read great reports about the DBA T3 rotors, so I asked Gary if he could source some. Never looked back. The non OEM pads still appear to be the week link, with a bit of squeaking at low speed and quite a bit of dust.....and still a bit of fade but nowhere near as bad as before. The T3s are still in great nick years later.
    So, it's interesting that a couple of guys on here are reporting no issues with RDA equipment. Bad batch maybe?
    Either way, I'll stick with the T3s and source an alternate pad when the time comes.
    Kev.
