Results 1 to 10 of 32
Thread: Oil Pressure light on instrument cluster
    Feb 2020
    Vic
    Hi all,
    Can anyone shed so info for me. I was on an interstate trip recently, and after driving about 200kms, the engine oil light came up on the dash, car momentarily lost power, so i backed off throttle, and pulled over immediately.
    Car stalled when i pulled to kerb. I popped bonnet, and checked oil, it was low, but i had oil (disappointing after a recent post trip service). Anyway.
    So i started the car again and it was running rough. So i shut it off again, and got towed home.
    Other information: I have a scan gauge fitted to vehicle, both engine (90deg cel) and trans (70deg cel), were within normal temps ranges, and no other alerts came up.
    Does anyone have any ideas what happened? Im suspecting oil pump failure for some reason, can has 245ks on it, and trans was fully rebuild 60ks ago.
    Any suggestions, or has anyone encountered this before?
    Dec 2009
    Ranelagh, Tasmania
    Quote Originally Posted by Azza_LR3 View Post
    Hi all,
    Sounds a lot like a major failure, probably a crank bearing, possibly oil pump but more likely a bearing.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Feb 2020
    Vic
    Thanks, so ive done some investigation and checked out a few things,
    The oil was free of debris, after i filtered it, However, oil filter has moderate amounts of brass dust on bottom of this.... Telling me its chewed out a big end bearing or 2.
    So i shoved my borescope up the sump hole and took a peek inside. Basically, its appears i have chewed out the mains bearings for CYL 1 & 2, As they were starved of enough / any oil,
    So its undoubtably caused by the infamous 2.7 diesel oil pump failure. Which as ive been made aware was a huge issue years ago, somehow mine was not replaced under recall in 2011/12, thanks to previous owners......
    So now i must remove and repair the engine....... Which is quite a timely and costly job (as body needs removal off chassis).
    Anyway I will keep you all posted, as i progress to getting my beast back on the road.
    May 2014
    Point Cook, VIC
    Gee the bad luck stories continue.
    Sorry to hear this.
    Sounds like you have joined the infamous spun bearing club. But losing oil pressure before the failure is different so does point to either lack of oil or an oil pump failure as you suspect.
    Not aware of any oil pump recall, but the must do recommendation is to replace the oil pump with timing belts and make sure you have the latest upgraded pump which is reinforced and has a larger impeller.
    Can I ask what oil spec you were running since you owned it?
    Plus any issues with starting the car in recent times?
    Sep 2014
    Baldivis WA
    ... checked oil, it was low, but i had oil (disappointing after a recent post trip service)...
    What was done at that post trip service? Was engine refilled to the correct level? As others have asked, what oil spec was used?
    Feb 2020
    Vic
    Yes, a pre trip checkover was completed. A few weeks earlier, transmission oil changed, diff oil changes x 2, Engine was looked over, but they somehow missed engine oil. AS after it stopped , i noticed oil was low, but it was there.
    After some detailed inspection, and checks, i have found the issue. Oil Pump has failed for some reason, And starved the big end bearings of CYL 1, 2, which have chewed them out. Gold dust was found on base of oil filter, oil was generally clear of material, just some fibrous material in strainer. Oil was a little dark.
    So i will be removing the engine in the upcoming weeks, and rebuilding the engine, as i believe its the only way forward. or to retire the car..
    Azza
    May 2014
    Point Cook, VIC
    Will be interesting to see what you confirm when you strip it down. Also could have spun a main bearing which then starves the cylinder big end bearings of oil.
    What spec oil were you using?
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by DiscoDB View Post
    That wouldn't result in an oil pressure light though.
    May 2014
    Point Cook, VIC
    Quote Originally Posted by BradC View Post
    Agreed - could be one of the first oil pump failures seen (excluding the early model housing failures after a timing belt change).
    If so - supports changing pump every timing belt change even if you have the updated pump.
    The other variable is the low oil level and if it starved of oil whilst under load - depends on how low it was.
    Strip down should confirm. Not good either way for the OP.
    What is this infamous diesel oil pump failure - know of the tensioner housing failure causing valves to crash into pistons but I dont believe the oil pump itself has a history of failure.
    Also what was this oil pump recall of 2011/12 - never heard of it. Are you getting confused with the injection pump recall. If there was an oil pump recall my car has not had it and according to topix all my recalls are up to date.
    As others have said, sounds like a possible spun bearing.
