Results 1 to 10 of 25
Thread: How Many Hours to Remove an 2014 TDV6 Alternator
    Jun 2021
    GRINDEWALD TASMANIA
    What were the people thinking when they designed these cars, definitely not simple access to components to apply a maintenance program.
    As a protective measure I want to replace the brushes in my alternator, bolts requiring using a universal joint and 450mm extension to remove and the ambidextrous process to remove the screws fastening the power loom bracket.
    Been at it for 2 hours and still have not completely removed the top bolt to get access to the electrical connections and the critter removed.
    Thank my stars I am not on the side of the road with a dud alternator.
    Well my incompetency is duly flagged by the replies to this post, after a six hour slog I finally have the alternator on the work bench,
    The electrical connections on my vehicle are totally inaccessible without breaking the connection on the Starter Motor. This a fun chore without removing the starter motor as the connection tab blocks access to the terminal and requires the insulation boot to be torn.
    By doing this it allows rotation and forward movement of the alternator to get a socket fitted on a long extension to undo the alternator terminal, the fun will begin in earnest when its time for reassembly.
    The alternator has to be removed by dragging it through the top after fan and inlet duct and pipe removed, pipework negates dropping it through the bottom.
    Shuffling the alternator around to gain access to the single wire plug resulted in the wire severing, I will be lengthening this wire on reassembly to make life easier if there is a repeat of this disaster.
    Appreciate an image of others installed alternator viewed from floor level, mine looks nothing like the U Tube offerings. I will take some images of where my alternator sits tomorrow.
    Mar 2016
    Interesting. While it wasn’t straightforward, I’m sure I did mine in a couple of hours. My only issue was removing the variable voltage sensor wire on the back of it was difficult as I couldn’t work out the plug from underneath. I actually ended up cutting the wire and then soldering it back up once I got it out. The positive connector was a pain but I remember you could unbolt them alternator to get better access to it (I think).
    2007 Audi RS4 (B7)
    NSW SW Slopes
    The power diodes usually fail first, being avalanche type whereby their trigger voltage slowly lowers resulting in a dead short. If you're going to the trouble of removing the alternator before it fails then consider replacing it.
    Sep 2014
    Baldivis WA
    When I replaced mine, I did unbolt first then disconnect the wiring. Have to hold it near install spot to get behind and undo the connector. IIRC about 2h all up including pulling the underbody protection panels off.
    Apr 2010
    South Melbourne
    Is the D2 alternator susceptible to diode failure like this?
    As mine is original at 330 K km / 19 years 😳. ( but with new brushes).
    Simon
    2003 D2a TD5, ACE, SLS, Vienna Green.
    NSW SW Slopes
    D2 alternators weren't known for failed diodes so probably used normal diodes, not reverse switching avalanche / Zener diodes that deteriorate to short circuit.
    Avoca Beach
    My D2 alternator failed at 134KK, ( a couple of days after I bought it) because the front camshaft plug was leaking and the oil ran into the brush box, wearing the brushes out.
    Also my Negative stupid bolt down terminal was unable to be tightened and I think that exacerbated the issue.
    I was able to buy a new brush box from the UK and fitted it and have it as a spare, as well as had a new negative battery terminal fitted..
    So make sure you have a good seal on your front camshaft plug.
    Regards PhilipA
    Jun 2021
    GRINDEWALD TASMANIA
    Saga Continues
    Well you should leave sleeping dogs lie.
    Firstly let me clear one issue, the alternator fitted to my 2014 build L319 Discovery is Denso Part Number AH22-10300-AC, 10 42 10 2421 this cross references to Denso DAN 1105 which is a 150 Amp unit. I wont go into the complexities of LR Part Nos for this device except to add the very latest listing appears to be LR124836.
    Next gem of wisdom is the Regulator Part No in this device is GC6 3570 which can be sourced as a separate item.
    Now to the chase, as posted previously I removed my alternator to replace the brushes and bearings. Because this version of the SDV6 is twin turbo the access to the alternator is very restricted and the turbo pipe support bracket has to be removed.
    During removal I managed to sever the regulator excitation cable which I repaired and length extended to make assembly easier. I also inserted a join in the alternator cable where it terminates on the Starter Motor and extended its length to also make reassembly easier.
    I fitted a new brush box and rear bearing which was weeping grease. Cleaned and polished the slip rings. The front bearing I left untouched as it exhibited no faults.
    Refitting the alternator became a little easier. Initial engine start up went without problems and voltages measured at the battery terminals were compatible with a "normal alternator".
    Next engine restart, after 30 seconds, the Charging Fault appears on the dash, my scanner confirmed the fault and using the voltage diagnostic function revealed voltages only around 13V despite the battery not being fully charged.
    Right now I have the alternator removed for the second time, bench tested rotor slip ring and new brush box continuity, diodes for shorts, all showing no fault.
    I cannot duplicate the complex signal function that controls the voltage regulation on this type of alternator, "KISS" is not in Land Rovers vocabulary.
    Next week Alternator is off to the Auto Electrician to see if he has the resources to fully test this type of alternator, after I test to ensure there is no voltage drops in the alternator connection cables.
    If anyone has a means to diagnose how this drama has evolved I would appreciate it.
    Mar 2016
    Edit. I recall now it was 180amp and superseded to 150amp. Either way, it has no bearing on your issue.
    2007 Audi RS4 (B7)
    Jun 2021
    GRINDEWALD TASMANIA
    Error edited
    Quote Originally Posted by DiscoJeffster View Post
    That sounds like the wrong amperage. The original D4 alternator was 220amp IIRC and the replacement model was 180amp. That’s what I fitted as I couldn’t easily find a 220amp at the time. 130amp sounds very low. Are you sure it’s correct?
    Denso AH22-10300 -AC is rated 150 Amps
