Results 1 to 10 of 20
Thread: Front end alignment/ steering wheel position
    After this (done by dealer) the steering-wheel seems to be set to the right slightly (allowing for the road camber) I feel it should it be neutral as it was before. Does this happen when TTM is not done correctly?
    Nov 2015
    Black Rock
    Agree. It wasn't centred correctly. Surprising how annoying it is.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Sep 2014
    Baldivis WA
    Take it back. If the wheel is not centred, the alignment has not been done correctly. This is provided that your control arms and bushes are all ok. Worn bushes affect alignment.
    NSW SW Slopes
    Nothing to do with TTM set or not set though, just the aligner's idea of what's best.
    Sep 2014
    Baldivis WA
    Correct, just the steering tie rods not adjusted right
    May 2014
    Point Cook, VIC
    I always found the “it is off centre to account for road camber” a cop out to not getting the steering perfectly centred.
    A lot of multiple lane divided roads that we get around metropolitan areas camber to both the left and the right depending on which lane you are in.
    Jan 2020
    McGowanastan
    The car will also fault if the steering wheel is to far off being central. I replaced my arms and it faulted on the way to wheel alignment.
    Bulletman
    Sep 2014
    Baldivis WA
    Quote Originally Posted by Bulletman View Post
    Bulletman
    Yes, mine did too. Its tied into the ABS module as well. I had the fault codes that HDC, ESC and ABS were not available.
    NSW SW Slopes
    ABS faults occur when the steering angle sensor direction of travel indication conflicts with direction indicated by the wheel speed sensors. The steering angle sensor is connected to the ABS ecu.
    Mar 2016
    Which makes sense. Steering wheel not point straight ahead but all wheel speed sensors relatively equal frequency indicating straight ahead travel Front end alignment/ steering wheel position
    2007 Audi RS4 (B7)
