Results 1 to 10 of 13
Thread: D3 and D4 HSE have air suspension?
    May 2015
    Williamstown, Victoria
    I'm looking at a D3-D4 HSE do they have air suspension as standard? Do the seven seat vehicles have air suspension?
    Ta
    Bo
    Build date 11th Oct 2003
    LROCV #1410
    Mar 2018
    Perth (near Malaga)
    Yes
    Dec 2009
    Baldivis WA
    Yes, and yes.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Mar 2016
    Affirmative and affirmative. There are some exceptions of coils but I recall they were likely imports. Stick your head under a wheel arch to be sure if you don’t see the suspension controls in cab.
    2007 Audi RS4 (B7)
    Oct 2012
    Quote Originally Posted by DiscoJeffster View Post
    The S base model in very early D3 years had coil option. Don’t think manual was ever offered in Oz.
    St Helena,Melbourne
    4.28 MB
    All 7 seaters are on air regardless of trim level unless some heathen has converted it.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2017
    N/A
    Quote Originally Posted by Bohica View Post
    Ta
    Bo
    D3s - some base models had coils only.
    D4s - will have EAS unless someone de-specified it from the factory or removed it once it was here: I've seen just one factory-spec coil D4 for sale, a couple of years ago.
    Seven seats were technically an option on the D4 but again, it was standard on all Australian D4s unless you de-specced it from the factory. I saw one D4 without them a couple of years ago - you can tell because the 2nd row seats aren't 33/33/33 but are instead 60/40.
    Arapiles
    2014 D4 HSE
    May 2015
    Interestingly one is in Perth a UK. import, I've asked how when it was imported, still no reply.
    LROCV #1410
    Aug 2008
    Perth, WA
    37.36 MB
    I wonder if it was one of the South African specced versions as they made a special request to Land Rover for coil versions of the D4 for the African continent.
    Life is just a series of obstacles preventing you from taking a nap.
    Mar 2012
    melbourne
    A coil conversion would make maintenance a lot cheaper and the car a lot more reliable once it starts to get high km, it would also remove the risk of ending up on your bump stops in the middle of nowhere
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
