Results 1 to 10 of 11
Thread: TDV6 alternator replacement
    Dec 2019
    Blue Mountains
    I was in a discussion on reddit about 70 series Landcruisers and a bloke popped up and said that Discos need to have the body lifted off the chassis to change the alternator. I know for a fact it ain't true for a Disco 2 because I certainly didn't when I swapped out my alternator. He came back and told me he "believes it's the TDV6". I had a quick trawl through here and couldn't see any mention of it. TDV6 Alternator Replacement. This thread certainly didn't seem to require such extreme measures. Any further info or was I right to call BS.
    Oct 2012
    Total BS. Easily changeable
    Dec 2020
    Diamond Creek, Vic
    Quote Originally Posted by PerthDisco View Post
    Easily?? Feasible, and there are definitely harder jobs to be done. It's no fun if it's not a challenge.
    Oct 2012
    Quote Originally Posted by Airmech953 View Post
    Ratchet spanner essential!
    Jul 2008
    Launceston, TAS
    I did it the other day following these instructions and found it pretty easy. Not as easy as a simpler, older engine perhaps, but I haven't worked on cars in years and I was able to sort it out in a couple of hours. The ratchet spanner certainly made it a much easier job
    Brisbane,some of the time.
    Quote Originally Posted by A Gringo View Post
    Not body off,but compared to a 70 series 1-VD,much more difficult to do.
    Mar 2018
    Adelaide
    Ha ha, if I, of very little tools, space and experience can change the alternator under my carport it is certainly not a body off job.
    Granted, it took me 3 hours as I don't have a tool to remove the fan and (at the time) I had no ratchet 13mm spanner (bought one next pay) it was actually a straight forward swap. I won't say it was easy, but it was done with no special tools.
    Sep 2014
    Baldivis WA
    Quote Originally Posted by swiftnets View Post
    Not bad going, but the fan doesn't have to come off to get the alternator out. Access from underneath is straightforward once the belly pan and intercooler short hose is removed. Hardest part is getting the cable connector at the rear to go back on.
    Apr 2012
    Whyalla, SA
    Oh dear…. It’s a simple job on a TDV6. Just an hour or two.
    Go back and ask old mate LC how it goes doing a starter motor on the V8 TDV6 alternator replacement
    Oct 2012
    And #1 Ronny Dahl mod is to swap to a water cooled aftermarket alternator as they fry out in first water crossing on the Toyota.
