Tennis club friend has an expensive lawn ornament previously known as a 3.0 D4. As the title suggests, I'm curious as to whether a 2.7 out of a D3/D4/ Territory will fit in its place. I've seen a thread somewhere here maybe, just cant find it right now.
Thanks Dave
PS: How do I change my username to DaveTDV6 or whatever?
2015 D4 TDV6 White 185,000km
2008 D3 TDV6 SE Arctic White 290,000km (The Panda)
2003 D2a td5 Monte Carlo Blue 370,000 (sold)
1996 D1 300tdi Manual some greeny blue colour 240,000km (sold)
Cheers, Dale
'The D3' - 2006 TDV6 HSE
Previously Enjoyed:
2000 D2 Td5 - plus!
Because a 2.7 has been shown to be a feasible "downgrade" whilst retaining all the 3.0 ancillaries. A TDV8 requires some physical adaptation and considerable work on the ECUs and associated interfaces.
A TDV8 would be great, but if you can just swap all your 3.0 bits onto a 2.7 long block it's a faster and less expensive option. There's a guy on the UK D3 forum who has done it. From memory he's a Kiwi.
I'd been led to believe that both options required ECU update/rejigs? But my vote is definitely with the 4.4 TDV8 or even the 5.0 V8 pettie if my current 3.0 throws a leg out again.
Just arrived: 2012 D4 3.0 HSE, the journey begins again ;-).
Gone: 98 Disco 300tdi Auto, and some extras
Yes it works, I've done 2 of them for friends/relatives, i dont offer it as an option to customers.
*You are stripping the engine down to just the bottom end block complete and the heads, everything gets removed (including the manifolds).
*The oil separators are different, the 2.7 has the oil drain back at the back of the block by the tone ring. The 3.0 has the drain in the top of the block at the back.
*The oil separators on both have a one way valve type arrangement, my guess is under full throttle the valve prevents the intake from sucking oil from the block.
*The oil separator from the 3.0 needs to be modified with a fitting to take a oil hose to plumb it to the block drain at the back of the engine, somewhere between the two you need to fit a one way valve, a pcv valve reversed, its all a tight squeeze.
*The heads on a 2.7 have one bolt hole on each side that is missing to mount the 3.0 egr assembly, one can be drilled/taped the other is missing the material on the block.
*Its lot and lots of work, more work than swapping a 3.0 for a 3.0.
*all the bits that bolt onto the 3.0 is needed.
*Keep the 2.7 water pump as the depth varies between the 2.
*keep the rear tone ring for the crankshaft position sensor on the 2.7
*I dont offer it to customers as the comment is typically oh downgrade it?
*which is a ridiculous statement, the difference in capacity from memory is 1mm in the bore and 1mm in the stroke, the 2.7 is a higher compression engine.
*While I havent dyno'd the 2, the power output would be at least equal if not better.
*So if the pcv / oil separator mod was more elegant and I didnt get dumb comment about downgrading, I'd prolly offer it to customers.
*I'm more interested in seeing if the block and heads from the ranger 3.0 are more similar.
Please dont private msg me asking about this, post here so everyone can read, assist etc etc.
Daz
wrong, no ecu mod needed, the ecu is not AI and only goes by what the sensors tell it.
all that extra power and torque comes from 2 turbos bolted to it
Daz
Its one of those do it if you're desperate or dont have the coin for a new/rebuilt 3.0, or you are a gluten for punishment and have the space and time to do it - i'd probably fall in the latter category![]()
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
again I would be more interested in if someone has used this business in nsw
Automotive Skills offer a rebuilt bare engine for $11K on a exchange basis.
Anyone know of this business or have used them?
Daz
