Results 1 to 10 of 14
Thread: Fault Code P115A-68 (2D) Low fuel level - forced limited pow
    Western Australia
    Returning from late shopping last night with D3 surging home the last 3 kms's.
    Gap shows 2 faults:
    P115A-68 (2D) Low fuel level - forced limited power - Algorithm based failure - event information
    P115B-68 (2D) Low fuel level - forced engine shutdown - Algorithm based failure - event information
    fuel guage shows around 150km's left
    Can anyone enlighten me as to the problem please?
    RichardK
    RichardK
    Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
    Jan 2010
    I know the D4's have this function to make people top up the tank so that they don't end up having to prime the fuel pump next to the road. I thought D3's didn't have this, mine doesn't as I've run the tank down till the fuel light came on a couple of times. For whatever reason the car thinks the tank is low, when you say 150km left are you judging by the tank level or the trip meter? Although if it was surging that seems to be low fuel or a blockage or perhaps a LP or HP fuel pump failing.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Western Australia
    Quote Originally Posted by RANDLOVER View Post
    Thanks for the reply.
    Both pumps were replaced 12 months ago, the KM,s left are what is shown on the instrument cluster, I thought this also mand will drop in 20 litres from a jerry this morning and see what happens.
    RichardK
    RichardK
    NSW SW Slopes
    Presumably the fuel level sensor is faulty unless the gauge itself is showing empty.
    Mar 2015
    Horsham Victoria
    I’m thinking if it was saying 150 till empty, probly means 15 litres left, gauge would show quarter if not under, so with travelling fuel sloshing about, my opinion is it’s just low on fuel and needs a drink.
    Western Australia
    Well all seems to be sorted, my initial interpretation of the IID seems to be correct, that when the fuel gauge shows empty it triggers a sensor to tell the ECU to force limited power or force shutdown.
    In this case I had 130 km's allegedly still in hand so there must have been a hiccup somewhere.
    I have now filled the tank, better off for the experience/knowledge.
    Thanks for the replies.
    RichardK
    RichardK
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by RichardK View Post
    That's really odd. I've driven >30k's past where the computer reported 0 km to go and put 83L in the tank when I rolled into the servo. No errors, no reduction in power. Admittedly I had everything off and was feathering the throttle as lightly as possible so I might not have noticed a "reduction in power", but still no errors.
    Mar 2016
    Quote Originally Posted by BradC View Post
    Same in my D4. I found there’s around 80km 8L left after 0km. Never hit the level error.
    I suspect the OP has a problem related to the level sensor. Waiting to see if it happens again.
    2007 Audi RS4 (B7)
    NSW SW Slopes
    Was the low fuel warning message issued?
    Mar 2018
    Perth (near Malaga)
    I didn't see anything other than the frantic orange low fuel light. Given the manual says the tank holds 84 and I put 83 in, it was right.
