I installed CarPlay in my 2013 D4 today, works perfectly, installed the blue control box under the gearbox rotary selector as per Cambo’s advice.
Only issue I’m having is that when I turn the car off my audio book or music continues to play. My phone is only connected via wifi. Has anyone else had this issue and can I do anything about this issue?
"Land Rover - making mechanics out of everyday motorists for nearly 70 years"
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
It uses USB, wifi or Bluetooth. But I thought it needed BT to control the phone functions. Learn sumfin new every day.
JayTee
Nullus Anxietus
OKApotamus #74
I’m a bit confused now. I connected my iPhone via Bluetooth direct to the CarPlay box. I removed my phone from the vehicles core system
 Super Moderator
						Super ModeratorThis probably won't make it any clearer then :
Carplay requires Bluetooth and WiFi. Your phone will be Bluetooth paired with the Carplay box. When it connects it'll use the Bluetooth connection to exchange credentials then it'll establish a WiFi connection and commence carplay. From that moment you don't need the Bluetooth connection any longer.
Conventional hands-free uses Bluetooth only.
Not that you'll want to, but with Carplay you can actually turn off the Bluetooth on your phone while it's connected and it'll remain connected. If you turn off WiFi however it'll drop out.
There's a serious WiFi interference spot in Perth across the Narrows bridge that causes interference if I'm using wireless carplay. So much so I've gone back to the USB cable because it's just more reliable.
Edit : After re-reading the original message. Is your carplay box after-market? Mine (different box, different car) has a specific "ignition" wire that tells the box I've turned the car off. It then pauses all media and drops the connection. It does have a continuous power feed to manage the settings memory and make for a faster boot.
My CarPlay box is an aftermarket. It’s one of the ones that Cambo sells.
Thanks for the info, I didn’t know that about how it connects to wireless. I’m now wondering if I should try connecting the USB cable and setting if that’s any help. I didn’t install the USB input because it seemed to work fine via wireless.
Back to pulling the dash apart again I think
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberWas it completely plug and play or did you have to pick up some trigger wires etc? I wonder if so, if you got the wrong wire somewhere?
Also, have you simply asked Cambo??
2007 Audi RS4 (B7)
I have a similar experience - the car switches off, so the head unit and amp stop, however power remains on for the carplay, because i picked up the power feed from the cig plug, which stays on for a short while.
Upside, is because carplay gets power when you unlock, it's booted and ready to play when you start the car.
Downside, is the phone remains connected, with the unit happily playing to an amp thats switched off. Once power to the cig plug/car play is lost (by locking, or time out) the phone loses connection, and pauses.
Doesn't bother me, as i listen to music, and so picking up a new song instead of the second half of the previous one is no issue. Bit different for an audiobook though.
Possible fix is to grab power from the console fridge box? that only has power with 'engine on'?
2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
Ok so I’ve solved the problem. The unit is completely plug and play which made the installation super easy. I’d been trying to not ask Cambo about this because I feel that I’ve been bugging him a lot lately about this.
What I’ve learnt (ended up messaging him) is:
1) everything advice is correct Re: wifi and Bluetooth
2) you can’t get the entertainment system to automatically start up in CarPlay - you have to press the navigation button every start up (CarPlay is installed using the navigation section of the entertainment system)
3) you can install the CarPlay USB input in place of the left cigarette point (next to the terrain switches)
4) once you use USB the music and audiobooks will stop as soon as you disconnect your phone. That’s much handier, going to do that. Also in line with what others have suggested. Unfortunately I didn’t install USB before closing up the centre console. I have to pull the centre console out again.
5) I’m currently using the left cigarette point to run my driving camera. Going to have to sort out now also. Might wire it straight into the aux battery, but that means that I’ll have to add a solar panel to keep it charged. Cameras use a deceptive amount of power.
I think that’s it
