Results 1 to 10 of 17
Thread: Sand blasting aluminium.
    Aug 2020
    Victoria Australia
    Hi Folks,
    Time to paint the hard roof of my Series 2A. I see that it is far from smooth with three main ribs and lots of little corners, edges and indentations. Does anybody know what the best way to get the old paint off? Is it safe to get the aluminium roof sand blasted?
    Thanks for all ideas and info .
    Dayboro, Qld
    I used paint stripper and a wire wheel attachment on a grinder when I stripped my roof for painting. Aluminium can distort when sandblasted, I had some floor panels done which weren't very successful
    Narre Warren South
    Quote Originally Posted by danniboy View Post
    Hi Folks,
    Depends what you mean by 'sand blasting'.
    Different media can be used (not sand). Most abrasive blasting companies would use a fairly aggressive media so you'd probably be better off with soda blasting.
    I've recently stripped part of a roof using paint stripper.
    Walter the Dormobile
    Wasn't fast but reasonably mess free as it was done in a garage.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Sep 2012
    Westlake ,brisbane
    I had all the panels of my 80" glass blasted but the guy I had do it really knew what he was doing. I believe Soder blasting is a lot gentler. I did strip a bonnet for one of my other S1 80's using paint stripper but problems with stripper that had got under the rivet heads causing the paint around the rivets to start to peal after a couple of months being in the sun. I had the bonnet glass blasted then water blasted before re painting.
    Mar 2012
    Soda blasting is excellent for aluminium (and fibreglass). Senko Abrasive Blasting in Brendale might be worth a try.
    Sep 2012
    Westlake ,brisbane
    If you go down the road of using paint stripper, make sure the one you use is aluminium friendly, I had one once that attacked the aluminium, it can also cause a lot of heat causing thin panels to buckle.
    Sep 2010
    The Hills.
    152.79 MB
    Throw my two bob's worth in here. I discussed having the shell of my FIAT blasted. I was advised that "sand" blasting would probably destroy it, and it ain't aluminium. Media such as garnet or walnut shell were also too aggressive according to the firm I spoke to. Plastic bead or soda were deemed to be ok. The pressure put through the blaster is also important.
    Quote Originally Posted by 1950landy View Post
    Wow, hadn't thought of that one. Thanks.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Apr 2019
    South Australia
    I had Sid sandblasted, a took the panels to a glass bead specialist but he ended up using garnet
    They are very good at what they do and took it very gently, the end result was excellent.
    That said, my current project, a 1959 Thames I’ve just used stripper which is excellent and takes all layers off in one go. Tested several brands and CAM is by far the best. Did the whole exterior shell in a weekend using two tins ($100 in total)
    PPE is essential though.
    There is a local firm that does hydro wet blasting which looks great as they come to you and do it in your drive. Thought about soda, but you do have to treat the shell afterwards.
    There is a dip tank place in Adelaide, but it eats aluminium so only on steel.
    Jan 2014
    Perth Western Australia
    *The biggest issue with getting car panels stripped using media blasting is the heat that's generated, which is what buckles panels.
    *A good blaster that can do panels will have no issue.
    *Media blasting such as alum oxide, garnet, glass etc is a profiling finishing, the courser the media, the more profile.
    *Soda blasting is a non profiling blast and less aggressive on the surface (turbine blades in power generation are cleaned using soda blasting)
    *Depending on the painter, some say you need a profile, some say you don't. This may be irrelevant with alum as you are using a etch primer.
    P.S with any media blasting, you get a degree of impregnation into the surface and it gets into all the tiny nooks and crannies making it very difficult to clean out.
    wet soda blasting has no adverse effect on the surface.
    Cost, the cheapest is prolly the paint stripper and your time
    Daz
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Cadas View Post
    Yonks ago a bloke I knew stuck his twin carby setup into one in a basket. Wound up with a basket of brass fittings.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
