Results 1 to 10 of 35
Thread: Tyre bead breaker - food for thought
    Land Rover - The leader in chasis rust protection with leading edge oil application system.
    2000 Discovery TD5 - ACE. 2" Lift and Bloody big lights
    2016 Discovery D4 SDV6 HSE ARB Bar, lights and winch. Wow
    Mar 2018
    Perth (near Malaga)
    Now that's interesting. Given the some 100mm of movement with the EAS that might be a goer.
    Nov 2014
    Nirvana near Albany W.A.
    Might have to overcome the Landy EAS's propensity for self raising first.
    Oct 2013
    Richmond, NSW
    Wouldn’t a hi lift jack foot plate on the Tyre have a similar effect?
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Ocean Reef WA
    I'm sure I saw someone using a hi-lift under the tow hitch and it did exactly the same job. This thread reminds me I've got a bead breaker down the shed I've never used and keep meaning to get rid of. I really must start decluttering the whole house actually of stuff I/we have bought over the years before looking around for a last house move.
    AlanH.
    4.28 MB
    I tried using a jack before on a D2 and it just lifted the car up without popping the bead. Try it at home before relying on it in the bush.
    Rod
    D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
    Quote Originally Posted by ATH View Post
    I have an R&R Beadbreaker that I haven't used since I've had Land Rovers with alloy rims. The AH2 bead on an LR rim is a bitch to break - oh, and there is a particular spot on the rim where you need to start trying.
    Aug 2016
    Just a question are compomotive rims just as hard?
    2016.5 TDV6 Graphite D4,Corris Grey,APT sliders,Goe air comp plate,UHF & HF radio,Airflow snorkel,Discrete Winch,Compo rims with 265/65/18 Wildpeak AT3W, LLAMs,Traxide dual battery,EAS emergency kit,Mitch Hitch EGR blank & delete,ECU remap
    Mar 2016
    Quote Originally Posted by dirvine View Post
    I don’t believe so as I’ve heard people dropping a bead on a Compo at lower pressures, that the LR rim would laugh at. It’s one of the saving graces of the low profile tyres - at least the rims let you lower far lower than otherwise acceptable to get you out of a bind.
    Happy to stand corrected.
    2007 Audi RS4 (B7)
    Sep 2014
    Bathurst, NSW
    Not trying to hi-jack the thread, but related.
    Has anyone ever used the "BeadBuster XB-550" or similar on a 19' or 20" rim? Looks the goods but is it strong enough. I suppose breaking the bead is only half the battle. I think getting a 19 or 20' trye off or on a rim would be near impossible on the trail.
    The BeadBuster XB-550 Bead Breaker! Howto and Review - Breaking down tires just got super easy! - YouTube
    2014 SDV6 SE, Fuji White, ARB bar, Fyrlyt 5000, Pioneer Platform, Traxide D4-5S, Maxxis 980 Bravo, GOE Compressor Plate, ICom-450 UHF, Red Arc Tow Pro.
    Elite Murray 2 Caravan 24'4" Tare-2917kg, ATM-3500kg
