Results 1 to 10 of 19
Thread: Still, could have been worse...
    Sep 2010
    The Hills.
    152.79 MB
    Brought the car home from where it's been hibernating to do a few things. Nasty vibration developed with backlash in the drivetrain.
    Timing is everything:
    I knew it had been neglected but not this much. That shaft was ok when the trans went in... or was it. I doubt grease evaporates. I also doubt I would have got many more Ks before transmission catastrophe. I'm not surprised by the rust, given where it's been sitting.
    I assumed.... Don't.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Feb 2023
    Newcastle
    Very lucky. Caught it in the Nick of Time.
    Some new uni's and a balance and Bob's your Auntie's live in lover.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Bosco15 View Post
    Not quite...
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Feb 2023
    Newcastle
    Aarrgg!! Parts that aren't meant to mesh wear quickly, hey?
    Bugger. Off to the wreckers you trot. 8-(
    Jun 2021
    Margaret River WA
    Lucky that was all the damage. With mine, very similar but took the rear of the transmission out... Didn't snap the shaft but destroyed the trans
    Not sure of your power mods etc but check Hardy Spicer for price on a greasable replacement, I was quoted around $500 for standard duty and about $850-900 for a HD type, sort of compares pretty well with what else is out there (also the Perth dept had 20 on the shelf!!)
    Redd
    May 2009
    Tatura, Vic
    Try Jeep Connection in Hallam.
    They are agents for Tom Woods shafts. I got mine through them.
    You are very lucky. I have a friend who lives at Gove. He was on a trip to Melb when his let go just Nth of Alice.
    Took his auto with it as well as all the wiring around the area.
    He had it shipped to A stealer in Melb. After it was quoted for repair, he traded it on a new Deefer.
    This bloke was pretty fussy on maintenance. He did a feel and visual before he left.
    On mine, I have to remove it to be able to grease the centre support bearing.This is not a bad thing as a check is much more thorough when removed.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Back down the hill.
    What are you going to do, John? Upgrade or swap like for like?
    I have a front shaft here, you can have; needs a uni.
    Feb 2023
    Newcastle
    I rebuilt mine, today.
    Two uni's into the double Cardon joint. $66.
    Front uni had already been replaced with a greaseable unit.
    Ha! Don't call them names.
    The uni's that come with grease nipples embedded in the main body of unit don't have enough space between the caps to get a grease gun on.
    Next mission. Fit some extended grease nipples.
    Sep 2010
    The Hills.
    152.79 MB
    Email sent.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Nov 2017
    West of Perth
    Quote Originally Posted by Reddirt204 View Post
    Yep, mine did the same!
    As the OP said, it could have been worse. :-)
    If at first you don't succeed, that's one data point. - xkcd
    2011 Discovery 4 SDV6 HSE
