Results 1 to 6 of 6
Thread: Handbrake adjustment disc movement now
    Jul 2013
    Goldie, Vic, Australia
    Hello all. I have just finished adjusting the handbrake, put the right wheel on, and was putting the left wheel back on, when I noticed movement in the disc. Old school cars, I would say its a lose wheel bearing. That is the effect I have. Any suggestions as to possibility of being wheel bearing, if so can I adjust it like on a trailer for example, of is it another thing that needs replacing by a professional?
    Apr 2012
    Whyalla, SA
    Gday
    Disc on a D4 floats in the hub, so until the wheel is clamped up you won’t be certain.
    Once it’s clamped up - do the “wheel wiggle” test.
    If there play in the bearings, they’re a sealed unit. Eg. Replacement. Use only hubs from SKF or Timken.
    Jul 2013
    Gday
    Thank you for that information Tombie. Mine is a D3, so I'm guessing not much difference.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by TheDonsWay View Post
    Yep. Exactly the same set up
    Jul 2013
    Handbrake adjustment done, worked nice and quiet twice, and the screaming started back today.
    I cant do anything much with it at the moment though, I'm trying to remove the filler plug on the auto do I can put the new fluid in, now the filer is changed.
    Aug 2008
    Perth, WA
    37.36 MB
    If you haven't seen it before, I found Bodsy's brake bible helpful for EPB adjustment. It may help in tracking down the squealing issue.
    DISCO3.CO.UK - View topic - How To ? - Change your Brake Disks Pads Shoes Sensors
    DISCO3.CO.UK Photo Gallery - Bodsy's Brake Bible
    Life is just a series of obstacles preventing you from taking a nap.
