Results 1 to 10 of 12
Thread: TD5 ECU
    Jul 2023
    TD5 ECU
    Hi I'm having issue with my 2000 110 Defender TD5 ex military. When I was looking at ECU i spotted sticker with handwritten note " Rework To RA PN° CYG69023-2" Any ideas what it might be?
    Jun 2013
    Universe A
    Quote Originally Posted by Martinko View Post
    I have no idea what it means, but I believe military spec units had some features missing/changed.
    What are the issues with the vehicle?
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by shack View Post
    From memory its Imobilsation removed
    Jun 2013
    Universe A
    Yeah, I was thinking it was that but I wasn't sure..
    Jul 2023
    While driving, engine stops suddenly without any warning complete loss of power only "check engine" light comes on. Then I can start it it will run for couple of minutes then it happens again. If I leave the car sit for longer it's fine again until I run it for 30-40 min sometimes longer.
    Jun 2013
    Universe A
    Could be a number of things, do you have any tool to scan for faults?
    The capacitors can fail in the ECU which can cause the issues you mention, they will probably be worse when hot.
    But you need to check for faults first before proceding further.
    Jul 2023
    That's what I was thinking but none of the scan tools I used would work. I used Toyota Techstrem which has ODB/2 ,generic BOSCH OBD2 scanner and G scan but nothing would work. Reading these forums It looks like you need specific scan tool for Landy. I'm i right?
    Nov 2015
    Yass
    Yes, you will need something like a Nanocom or Hawkeye as the Td5 ECU is not 100% ODB2 compliant.
    Jan 2014
    Perth Western Australia
    sounds like the age old oil in the harness plug.
    unplug and have a look, clean as needed. the oil can ingress all the way into the ecu
    Daz
    Jul 2023
    Quote Originally Posted by DazzaTD5 View Post
    No oil in the harness plug. Could failed MAIN relay or Inertia switch cause engine shutting down suddenly while driving?
