Thread: cost for 108 month/ 234K service
    Aug 2010
    mudgee
    Hi All,
    My D4 SDV6 is due it's 9 year or 234K service (done 195K though) and I am wondering what is actually included?
    I have one proforma invoice that a LR dealer sent me, as to quote him, " it is a big one at $3580".
    includes the LR065238 PAN - TRANSMISSION OIL at $720 (replacing it i assume? or is this just the oil and filter cost?),
    9L of LR023288 FLUID - TRANSMISSION for $1360 (equals $151 per litre!) and
    $855 labour (I assume labour at $120/hour = 7 hours work)?
    Everything else is reasonable.
    regards
    Peter
    Jan 2012
    Find a good independent LR mechanic…I’ve been using an indie for most of my D4 life and the savings / knowledge you’ll get are invaluable
    As a comparison
    Transmission pan / oil : ~$500 vs your ripoff amount
    At 234k you should have changed the transmission oil a few times by now (unless listening to the LR “sealed for life” BS)
    Seeing you are based in Mudgee..you may need to drive a little…but it will be worth it
    Brisbane,some of the time.
    A good Indi is the go,as said.
    At $120/hr,that would be the cheapest LR labour rate in the Country, by a country mile.
    Aug 2010
    mudgee
    Thanks for the replies and confirming my suspicions.
    so what LR indies can people recommend either in the Central West of NSW (assuming there are any) or in Western Sydney?
    Peter
    josh.huber Guest
    It's just the auto service pushing the Price up. Any local auto trans shop can do it. And they are usually cheap. You could source all the parts with help from on here, (MJ products from Victoria(eBay)) is my choice for oils and parts. Then the local can just drop and change it. No dramas.
    Aug 2010
    mudgee
    Thanks Josh,
    I have been looking at the MJ website as well!
    I will ask one of the local workshops to see if they are happy to do the work.
    peter
    josh.huber Guest
    Quote Originally Posted by pbhawkin View Post
    Thanks Josh,
    8-SPD Auto Trans Oil Pan Kit for JEEP, RAM AND LAND ROVER 8HP45Z 8HP75Z 8HP50Z 8HP70Z
    Better still. Get your local to call them and order what they need. Just get genuine oil. It's so cheap and easy to do. My local charged me $150 labour for the last service. I left parts he needed in the boot.
    Mar 2021
    Newcastle
    There is a indie not far from you in Bathurst, I haven’t used him but a couple of blokes I’ve spoken too have and said they are happy with him.
    Sep 2014
    Baldivis WA
    Thanks Josh,
    peter
    Buy the MJ kit and 20l drum of Penrite BMV and DIY. You will save yourself about a grand or more
    Aug 2010
    mudgee
    hi,
    All sorted with Pan and oil coming from MJ in Melbourne and local mechanic to do.
    10L lifeguard oil for $160 = $16 / litre NOT the $151 / litre from LR dealer!
    Pan for $350'ish.
    Interestingly, I requested another service cost quote (twice) from a Western Sydney dealer (where I bought the car from originally) and funnily enough they haven't been brave (stupid) enough to send it to me!
    The reason i worked out the $120/hr labour was they quoted the job as being 7 hours and $855 labour. But sounds like it is 3-4 hours ($213 to $285/hour)
