Results 1 to 9 of 9
Thread: D3 Flexplate alignment
    Jul 2023
    Victoria
    Situation: I have a D3 with the V6 petrol (ford engine), I pulled the transmission to replace the rear main seal. On start up the engine has a misfire and will not idle. (no issues prior and timing belts previously done). Error "A Camshaft Position - Timing Over-Retarded Bank 1" plus I get misfires across all banks.
    Questions: Does the position of the Flexplate matter?
    I think the crankshaft position sensor runs off the flexplate (not sure). Appreciate any advise before I go off and pull the transmission again.
    Hunter Valley
    Yes, it does matter. You're right. The sensor reads if the flex plate and can be installed incorrectly. It needs to be marked when it's taken off. There is a way to time it, I have a look in the manual and get back to you
    It doesn't leak oil, Its sweating power
    St Helena,Melbourne
    4.28 MB
    No timing belt on the 4.0 so I assume you mean the timing chains of which there are 3.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2016
    Irrelevant either way to the issue of the crank sensor trigger being out of place due to the flex plate incorrect positioning on reinstallation.
    2007 Audi RS4 (B7)
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by DiscoJeffster View Post
    True but if he doesn't know what the engine has then easy to get **** wrong.
    1974 VW Kombi bus
    Hunter Valley
    There is a hole in the flex plate, when the engine is at top dead centre cylinder 1, the hole is at 3 o'clock
    Jul 2023
    Victoria
    Legends - appreciate the help!
    Sep 2010
    The Hills.
    152.79 MB
    Out of interest, I take it that there’s no workaround and the trans needs to come out again?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Mar 2016
    Quote Originally Posted by Tins View Post
    Nope. Correct
    2007 Audi RS4 (B7)
