Results 1 to 10 of 25
Thread: 2002 defender cps issue
    Aug 2008
    latrobe valley victoria
    Unhappy 2002 defender cps issue
    Hey all…stranded at home again.
    Long story short ,I had a wire from the cps break and fixed it by twitching a scrap of wire in and taping it up……..ran perfectly for 3 months until I fixed it last night/today…….
    Won’t start…had a cps fault from the plug….also a no tach drive [there’s none on the car]
    I’ve a spare cps and I’ve tried that as well…both have the same ohm reading …
    I’ve tried purging the fuel rail
    Checked all fuses n relays
    Cleaned ecu[was clean already] plugs and engine plug
    As far as I see there’s 2 other options
    Cut back the cps Leads a bit and solder on a new section,check fuel presure reg wires to as they came off….
    It’s a battery/alternator issue…….I had a dead flat[clicking relay flat] and I’m fairly certain I’d left nothing on[98%]….it’s on charge but at 12.7 of the charger…no go..drops to 12.3 after 10 sec’s key
    My alternator is low ish on output as well[I’ve a spare]13.2 to 26v …
    Battery colapsed?
    All sugestions greatly appreciated as it’s 30 km to town
    Cheers mark
    2002 defender 110 , 1955 86 inch
    Sep 2010
    The Hills.
    152.79 MB
    Dunno about Deefers, but my TD5 disco won’t start if the battery is even a little low.
    As for the CPS wiring, mine has had it cobbled together for about 18 months now. Never seems to be a problem.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    CPS?
    Cycles per second - aka Hz?
    Jul 2003
    CPS?
    It's a TLA
    Mahn England
    Ex 300Tdi Disco:
    Jun 2013
    Universe A
    CPS?
    Crankshaft position sensor.
    But I'm guessing you already knew that!
    Aug 2008
    Battery
    Quote Originally Posted by Tins View Post
    Yea I’m thinking it’s colapsed……I had it on full charge and the voltage on the nanocom dropped from 12.8 to 10.3 in 5 cranks
    I’m thinking the ecu needs 11+[11.9 v?]….starter might have been a bit slow.
    Batterys off the car to see how it behaves [overnight 4c here] see what the v drops to
    Nov 2014
    Nirvana near Albany W.A.
    Yes, check the battery for spikes.... I think it's Cactus
    Quote Originally Posted by shack View Post
    No, I didn't.
    Cooroy, QLD
    I had a world of trouble with the CPS wiring on mine after I put in the new engine. Ended up raiding an unused plug that was hiding up beside the brake booster and soldered it in, has been fine since then. I found advice online saying not to solder to the loom but the available space is so short there was really no choice. I keep meaning to go back and shield that section but haven't yet.
    If you're getting CPS faults and you know the sensor itself is good (mine was new) then the loom is probably the issue - it's a bad design.
    Aug 2008
    Legend
    Quote Originally Posted by akelly View Post
    Yea there both good[cps] but the plugs crap……..was searching for one to scrounge
    I’m betting on dead cells in battery as well ….won’t hold over 10ish volts on nanocom whilst cranking
