Results 1 to 4 of 4
Thread: Tourertop Canopy Defender 130
    Cooroy, QLD
    Does anyone have the original tourertop fiberglass canopy for their defender 130? I picked one up but it didn't have the brackets/clamps that hold it to the tray. I'm trying to work out what clamps will work with it because the inside 'shelf' on the canopy is a fair bit wider than the top of the tub so it overhangs inside by about 50mm. The brackets on my amarok tub definitely wouldn't work. At the moment it's just screwed down with some right angle I had in the shed but I want to fit it properly with a new seal.
    Pics of the brackets would be great, if someone knows which ones work and where to buy them even better. Can't find much on the old tourertop canopies online, everything is just the new stuff.
    If I can't find something that works properly I might just run square tube along the inside of the tub and use the universal brackets you can buy on ebay.
    Adam
    Ipswich QLD.
    Mine doesn't use brackets at all, It just has bolts through the "shelf" into the capping on the tub. Just 1 M8 bolt in each corner. Might sound inadequate, but has been like that for the last 400,000km. Was fitted by British Off Road.
    Cheers, Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
    Cooroy, QLD
    Quote Originally Posted by Killer View Post
    Cheers, Mick.
    Thanks Mick.
    my experience with the capabilities of that crew tells me I'll do it a different way....
    Think I'll run a bit of bar along each side and use some universal clamps.
    VladTepes's Avatar
    Bracken Ridge, Qld
    My canopy (and also than on my previous ute) have both been held on my 4 or 6 bolts, as described by Killer and it has never been a problem.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
