In my view it would be, although it will depend to some extent on the condition of the Series 3 engine.
I Was going to get rid of a series 3 traytop, but was wondering if it was worth stripping the engine and gearbox, using them in a series 1 that had the holden 138 engine.
Does anyone think this is worth doing?
Thanks Ben.
Thanks John,
Should have said, it's a petrol 2.25L 4. Needs a little work, starts instantly and runs smooth with more power than I expected. However it does blow some smoke and has a tappet rattle.
I was going to sell it and put the money into the older vehicle but the landrover engine is tempting (not that they ever had that engine).
Regards,
Ben.
Well, the 138 is only a slightly bigger capacity than the 2.25 ( 2.26 ), and IIRC would be heavier than the Rover. Who knows, if you advertise the 138 on a Torana forum you might get a bob or two.
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
JayTee
Nullus Anxietus
OKApotamus #74
The principal advantage of the Rover engine compared to the GM engine is that the Rover engine suits the gearing of the Series 1 (same as the Series 3) better and if used as intended, is more tolerant of operation on inclines, and the lubrication system is designed for prolonged use at low speed, which the Holden one is not. And it fits the engine space better.
One thing to be aware of though is that the Series 1 bell housing is different to the Series 3 4 cylinder engine - you need one from a 2/2a if using the Series 1 clutch linkage. (and the bell housings differ according to the date of the box as the layshaft was changed - I think!)
I have a series 1 with a 2.25l from a IIA and it's definitely a good idea. The only hurdle really is the alternator mount - the engine sits lower in the chassis rails than on a IIA or III so the alternator has to sit higher. I just made an adaptor bracket to lift it up a bit and it works fine.
I had my S1 re-rovered from a 186 red motor. Absolutely worth it (s2 2.25 put it). Sold the red motor and its gearbox too.
The Holden Grey is a period conversion , not many around percapita, I'd be inclined to leave it.
