Thread: cvu unit
    Aug 2008
    16.28 MB
    cvu unit
    WHERE??? Can Iget either a reco or new CVU for freelander 2??
    Umm, VCU?
    May 2006
    Ulverstone,TAS
    The FL2 apparently doesnt have a VCU.
    Check your brakes arent sticking on especially handbrake.
    DG
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Jan 2024
    Pert WA
    Quote Originally Posted by INDABA View Post
    WHERE??? Can I get either a reco or new CVU for freelander 2??
    I suspect you meant to type VCU (Viscous Coupling Unit) which on a Freelander 1 is a sealed unit positioned in the centre of the prop shaft containing a viscous fluid to effect transmission engagement of the rear axle.
    You have posted on the Freelander 2 thread. The Freelander 2 does not have a VCU, but instead has what LR refers to in its technical manual as the "Active on-demand coupling" but it is in fact a Haldex Generation 4 wet clutch bolted on the front of the rear differential. This device is also used in some VAG, Ford and volvo vehicles.
    Indaba, do you have a Freelander 1 or 2?
    Aug 2008
    16.28 MB
    vcu
    No, I do not
    This is a mates car, I admit that I know nothing about it, BUT ..... this is the start of the learning curve
    One bloke said that they are sealed, THAT!!!!! I willguess is the cause of problem
    We will have to wait and see
    I have been trying to get or borroe a workshopmanual
    Doashcrofts have them??
    Well we need to know what vehicle you are talking about - the Freelander 1 and Freelander 2 are completely different vehicles. The Freelander one has a Viscous Coupling (uses fluid) where the Freelander 2 uses a Haldex system of clutches to regulate drive to the rear.
    Tell us what vehicle it is so we can answer.
