Results 1 to 10 of 12
Thread: 2010 D4 battery positive terminal
    NSW Far South Coast
    I have a 2010 D4 and my battery positive terminal can't be tightened any more.
    I've done some adjustments to it to get it to hold but I don't trust that it wont break somewhere 'back of beyond.
    Has anyone found a suitable replacement, short of a complete harness, or a work around with available items.
    Trevor
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by ytt105 View Post
    Trevor
    What the heck happened that it cannot be tightened? Is it buggered or is the battery terminal worn and undersized?
    Jan 2010
    Nut or bolt stripped?
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by RANDLOVER View Post
    I put a longer bolt in mine, just ground down the sides of a standard bolt so that it fits- job done.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    NSW Far South Coast
    Nothing is broken...yet. It's just that the cone can't pull down any further. Maybe the battery terminal is worn. I've ordered some shims and will see how they go.
    I am really after some ideas on how to replace the connector with something more readily available incase a problem occurs out in the boondocks.
    Trevor
    Dec 2016
    Replacing the connector would mean modifying the harness - I wouldn't do that.
    So the terminal of the battery is too thin/small for the connector to grip? How strange.
    Maybe you could use a sleeve/shim similar to this:
    https://autobarn.com.au/ab/Autobarn-Category/Shop-our-Full-Range-by-Brand-at-Autobarn/Projecta/Projecta-Lead-Shims-%28Positive-%26-Negative%29-Converts---BTS-2/p/EL18456
    Or replace the battery
    EDIT: snap just read that you ordered shims
    Nuggets
    Discovery 4 3.0L 2010
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Disco4TT3 View Post
    Oh well, I learned something. Never seen those before. Might be a solution to a similar problem on my D2.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Those packers might be a bit on the thick side.
    Try a bit of copper sheet remade from some copper pipe, or a bit of metal from a tin can (with the paint removed - think sandpaper), or do the same with a soda can. Although it is aluminium it can still be fashioned to increase the clamping pressure on one side while allowing the clamp itself to mate with the post on the other.
    It only needs to be there until a new battery is required.
    I have even seen a self tapping screw inserted between the clamp and the post. The post is of softer material so the screw hardly touched the clamp.
    Sep 2010
    The Hills.
    152.79 MB
    I've used shim brass in the past. I would need to see those packers in the flesh.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jan 2010
    Replacing the connector would mean modifying the harness - I wouldn't do that.................
    I'll admit that I too thought of modifying the battery post wiring as my back up battery is an Optima Yellow Top, but due to the L-shape of the D3 +ve cable terminal it won't fit, however I bought one of these instead...... OEX Battery Terminal with Dual Output Posts - ACX0043 - OEX | Repco Australia
    1999 D2 TD5 Gone
