Thread: EPB Repair
    Capel WA
    EPB Repair
    Just thought someone out there might be interested to know, I recently had the over joyous experience of repairing my Electronic Parking Brake actuator and as a matter of course replacing the rear brake rotors, pads and shoes on my 2011 D4.
    It only took me a week, pretty good huh.
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Patrick M View Post
    If you include procurement and planning time, most tasks on the car take me 3-12 months, so a week sounds pretty damn good!
    Oct 2012
    Having just replaced EPB shoes they are akin to a Mensa mental puzzle working out the trick to get that big spring in place, dogbone inplace and retaining clips on with only two hands.
    Capel WA
    Quote Originally Posted by PerthDisco View Post
    Yeah I am fully aware of this problem as well, I found that the diameter of the spring wire is too big for the holes in the shoe's it is supposed to fit into so I measured the wire diameter and reamed out the hole in the shoe, just enough for the spring wire to go through, I also found the very end of the wire where it also is supposed to go through the shoe is slightly too long, so I modified it by grinding a millimeter or so off, with these two mod's done it allowed the spring to slip straight in, once it is stretched to the right length.
    Aftermarket stuff, didn't check to see if they can from China or not though
    Capel WA
    Quote Originally Posted by BradC View Post
    Ahhh that's really sweet and nice of you to say that.
    My next job's are the timing belt's, oil pump and the water pump.
    Figured I would do all at the same time to save pulling bits off again later.
    Preventative Maintenance?
