Results 1 to 10 of 19
Thread: D3 TDV6 2.7 possible diesel leak
    Jul 2012
    Toogoom, QLD
    Got a strong smell of what I take to be diesel around front of the vehicle, I suspect of being a fuel leak somewhere, cant actually see anything dripping out though.
    It is running normally.
    I do have a very slight power steering hose leak, but does not smell like that sort of fluid.
    Any likely places to check?
    ta
    me
    Oct 2012
    Top engine all around the injector lines and return hoses.
    Fuel cooler which is under the engine.
    Should be reasonably easy to spot.
    Jul 2012
    Toogoom, QLD
    Quote Originally Posted by PerthDisco View Post
    thanks mate will have a look later and see what I can see. I would have expected fuel pressure fault codes if it was leaking??
    Oct 2012
    Quote Originally Posted by PeterOZ View Post
    No it leaks quite happily on the delivery and return side with no codes or loss of performance
    Jul 2012
    Toogoom, QLD
    glad it is happy
    Oct 2016
    Perth, AU
    glad it is happy
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Jul 2012
    Toogoom, QLD
    had a look at home and there is what looks to be weeping in vicinity of rear drivers side injector but nothing noticeable when engine is running so assume it is probably the clip broken or come loose on that return line.
    I can see accumulated wetness but not a puddle per se.
    Will probably need a set of return lines. There are a few youtubes of blokes doing them, Shanes Shed and Outback discovery.
    It is going in to have the auto removed and sent off to be made shiny on Monday so might even get him to do the leak then while he has it.
    Peter
    Jul 2012
    Toogoom, QLD
    Have ordered the parts.
    - Leak off pipe P/N 1386505
    - Leak off pipe clips P/N C2S32276
    Hopefully they arrive Thursday and I can get the job done, not looking forward to it at all.
    Better buy myself a pair of long nosed bent pliers and pinch pliers too.
    St Helena,Melbourne
    1.13 MB
    - Leak off pipe clips C2S32276
    Not a hard job but be careful to not lose any clips. Stuff rags down where ever you can and keep a magnetic pickup tool handy.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2012
    Toogoom, QLD
    Indeed, that is the plan, I have ordered clips just in case. Have several magnetic tools ready.
    Will give it a blow out with the compressed air and squirt some contact cleaner to mitigate dirt getting into the orifice.
