Results 1 to 10 of 11
Thread: DiscoII Radiator Change
    Oct 2003
    Montrose, Vic.
    Well, changed the Radiator in the Disco today.
    That was an interesting experience
    I am very grateful I had some experienced assistance there to help....
    What ever happened to 2 hoses and 4 bolts holding a radiator in?
    I just have to know...
    What were the Land Rover engineers smoking when they decided the first step to changing the radiatior should be "take out the headlights"
    Anyway.. all sorted - the cooling system is now fit to play in the sand at Fraser Island..
    Airbags tomorrow... and we are just about all sorted...
    Mark
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    99.87 MB
    I did all of this on the side of the road. I'll I can say, is that the Solihull designers and engineers are all a bunch of stoners.
    I couldn't believe it when I was pulling the blinkers out to get the headlight trim off to pull the grill out to get the horns out to undo the radiator mounts. Then the fan was meant to come out, like I had a special fan tool...not. So the raditor now comes loose and has to have the intercooler released and removed and then the ATF cooler removed also before the radiator would come out - but only just through the gap left. Then you need the hands of a 5 year old to do the lower hose clamps up, weird angle tools and zip ties to keep the hose clamps open while you slide them around. Not to mention having to drill holes in the new radiator so the coolant would flow through the blocked off lower passages.
    I need a beer just thinking about
    Slunnie
    May 2003
    On The Road
    you pair are a barrel of laughs,,,
    not.
    luckily enough Mark,,
    its quite pleasant up here at the moment---
    nice swell on the ride home yesterday--
    airborne on the back deck-- yeeha!
    Oct 2003
    Montrose, Vic.
    Quote Originally Posted by Pedro_The_Swift
    not.
    I'll try and remember to leave my melbourne weather at home!
    This is going to be a very long 3 weeks waiting to go....
    Mark
    Mark
    May 2003
    On The Road
    cant believe you had to replace a rad,,,
    what went wrong??
    99.87 MB
    not.
    What did I say?
    ok, maybe I can lighten up the mood a bit with a Saturday joke.
    Ya see, there was this designer in Solihull working on the D2......... just kidding!!!!!!!!!
    what went wrong??
    I crashed into mine with an engine. Unfortunately it was my engine. Too much water, too much speed.
    Slunnie
    Oct 2003
    Montrose, Vic.
    what went wrong??
    Was leaking between the core and the plasic side tank... had been repaired by the previous owner - and my trusted mechanic suggested that while I could get it repaired... I was probably better to replace it as most that he has seen repaired failed again fairly quickly
    On well......once again my trusty Landy saves me the worry of deciding how to spend my pay...
    Mark
    Mark
    May 2003
    On The Road
    nothing like keeping a spare radiator hanging around---
    May 2003
    On The Road
    Quote Originally Posted by Bytemrk
    Mark
    only 1 for me!!!!
    and then I'm off on Mrs Pedro's "Magical Mystery Holiday" (R)
    SYDNEY -in the shire.....
    only 1 for me!!!!
    she is sending you away on an R rated holiday.....?
    she must be planning to take the landy off road in your absence without you knowing about it......
