Hey, looks really good. Same year as mine.
I was happy with the state of mine when I got it but this one looks better.
 Master
						Subscriber
						Master
						SubscriberHi all
After much looking around at various Series 1, 2 and 2A's. but finally purchased a Series 1 in last few days
I think it is in reasonable condition and fairly original - it was running a few years back before it had a rest in the shed- will know soon enough.
I am a long term D2 TD5 owner (since 2008) - based in South Australia.
I am sure I will be on here asking for info and where to get things - quite soon!
I will post a few photo's this weekend - always looking for comments and guidance!
1952 Land Rover Series 1 ? RVs & Campers ? Williamstown, South Australia | Facebook Marketplace
Nobby
 Fossicker
						Supporter
						Fossicker
						SupporterHey, looks really good. Same year as mine.
 Master
						Subscriber
						Master
						SubscriberHi and Thanks
Great - you might have a few thought/research on what bits are original - especially the bits currently missing like
seats,
soft top hood
air cleaner - precleaner/cyclone
I think it came with the/a suitable ventilator flap - but I need to make sure it matches/fits etc
Nobby
 Master
						Subscriber
						Master
						SubscriberHi all
Here goes the first of what I am sure will be many questions....
The seller of the S1 - couldn't remember if the 52 model was Positive or Negative earth - is there an easy way to tell? He had it running 7 years ago ...but can't remember. Any tips would be gratefully received!
Also I assume it is ok to start and run it without the centrifugal air pre cleaner ? (If anyone has a spare on of those to sell - please Pm me!)
Nobby
It will have been positive earth new.
Connect a battery, with the larger clamp on the positive, ensuring nothing is on. Switch on headlights. The ammeter should now show discharge. If it shows charge, you have wrong polarity.
The only polarity sensitive wiring as sold is the ammeter, and this needs to be reversed connections if changing (and the battery momentarily shorted through the generator.
Warning. The usual reason for changing polarity is to connect negative earth equipment, such as radios or an alternator. These are likely to be destroyed if connected to the wrong polarity.
 Master
						Subscriber
						Master
						SubscriberJohn
Thank you! That sounds like a simple test - it has no radio's etc nor an alternator
I will test it - with a battery that I have here
then...
I will then source a long term battery, clean the fuel tank (interesting looking sludge/syrup in there - but lucky it is galvanised and in fairly good shape), see if radiator/ holds water, oil seems fresh and in good condition - and see if it will start!
the journey begins ...
Nobby
 Master
						Subscriber
						Master
						SubscriberHi all - some photo's of the new toy!
any comments welcome
Nobby
 Master
						Subscriber
						Master
						SubscriberNobby,
All Series 1,2 and some IIA were positive earth except for some special build army models etc. Positive earth works well as long as you don't want to run modern electronics. I like the nice paint patina on your new toy- don't paint it!
Also, dont try to start it until you drain the old oil (sludge!) and put some new mineral 20W/50 or Nulon X-Pro 25W/60 oil in it. It will run without the pre cleaner, but may be a tiny bit lean. They tend to run rich anyway due to wear and tear in the carbie and worn float valve etc, so don't panic. Set the timing at about 12 degrees and points at 0.014". If it still has the original Lucas DVXH4A distributor, you can buy good quality points, condenser and rotor from Heads Tractor Spares, (same as grey Fergie). Don't put one of those junk aftermarket carbs on it. Rebuild the orignal. Most S1s have aftermarket fuel pumps that are usually way too high in pressure, causing flooding and rich running. If has the original SU LP pump , the diaphragm will probably have gone hard by now, needing replacement. They run OK on 91 fuel with Flash Lube to protect the inlet valves, and seats. The exhaust valve seats have hardened inserts. I have a fairly original '53 model, which is nearly identical to yours, so Pm me if you get stuck, or need info.
Cheers, Mike (5380)
 Master
						Subscriber
						Master
						Subscriber
Nice buy!
It looks like it's been in dry storage and has not been altered too much at all, very,very, lucky!! Just needs some new seats and a few odds and ends to tidy it up. Very tidy under the bonnet. Looks like the correct Lucas DVXH4A dizzy, but with a Grey Fergie cap and later aluminium bodied coil and AM fuel pump. The dash looks OK, but the red and black accessory / trouble lamp sockets are missing. The only hard thing to find may be the missing conical pre cleaner, but someone may have a spare one in the shed. They were fitted up to the 1954 models as well.
I can probably help you with the accessory sockets and other small parts. I can also help with a pair of ST51 tailights with bar if you want to do a swap for the later 1954 no-bar lights fitted to yours. Charlesworth Mouldings in the UK do horn buttons etc. for you steering wheel switches. Be careful if you feel the urge to remove this switch, the clamp holding it in place is at the bottom of the steering box! The stator tube with wires runs all the way down through the hollow steering column to the above mentioned clamp at the bottom.
Take heaps of pictures and used labelled HD zip lock bags as you go. Saves a lot of head scratching later on! Try and save as many of the original BSF and BA fasteners as possible., they are god quality and hard to replace. If you PM me I can send some pics of mine if that helps determine what's right and wrong with your new toy. 5380
 Master
						Subscriber
						Master
						Subscriber5380
Hi and thanks - yes it looked to be fairly original and in reasonable condition!
Big learning curve for me - mainly experienced in "more modern" early Holdens (EJ and HR) and of course a newer Disco 2 TD5 (that I trailered it home with)
Is the Grey Fergie distributor cap ok short term ?
I hope the fuel pump is not too high a pressure as well
I can source a replica air pre cleaner from the UK but would rather a period one - if someone has one
I also need a set of wiper motors and gear - missing when I bought it
I have the vent under windscreen ( I think that fits) - that was supplied separately by prior owner - might be missing a latch/adjustment on passenger site - would be great to get some photo's of an original set up to check
I plan to prep and paint the chassis in a rustproof paint but leave the body/panels fairly as is - I like the 72yo patina as well
lots to do - but first thing is to get it running - I dont think that will be too hard as it has compression and was running ok a few years back - but lets see.
Will buy a box of HD zip lock bags ...good idea
Will PM you as well
Nobby
