Measure the downpipe under the turbo with a caliper, simple as that
What size pipe do I need for a Td5 cat delete?
You can also just buy a delete pipe, which replaces the original pipe back to the muffler.
They say this is for off road use only...... CTA.
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
Is there really enough good stuff in a D2 cat to cover the postage across the country, James?
JayTee
Nullus Anxietus
OKApotamus #74
You could probably just buy a pre-update down pipe pretty cheaply from someone dismantling a Disco2. They never had cats in them.
Potentially the benefit of buying one of those fandangled ones however, is that I understood the factory flex is a choke, and it might address that if its an issue. I've never looked inside mine.
Slunnie
